Mike Thomas
Mike Thomas's Avatar
"Oil" seeping from floor mats
I was detailing my (fairly new to me) car today, and when pulling out my decorative floormats (as opposed to the floorpan carpeting) discovered that the rubber backing on one of rear ones was exuding an oily substance. The floormat carpeting itself was clean and dry, but the bottom was really gross. I ended up piling up about 10 paper towels and stepping on it over and over to squish out the stuff, and out it came -- gobs of it. Anyone ever seen anything like this before?
The closest thing I've seen is the rubberized earpieces on a pair of Bolle sunglasses I had started "weeping". It was so gross that I threw them away.
Old 09-20-2008, 09:29 PM
RETIRED
Joe Bob's Avatar
Your don't mention the year model. Some mechanical speedometer drive cables have been known to pump oil up from the transaxle due to a minor seal failure and deposit it on the driver's floor pan.....
2012 ML350 3.0 Turbo Diesel
Old 09-20-2008, 09:39 PM
austin552's Avatar
True, mine is leaking in the tunnel.
1974 911s
Old 09-20-2008, 09:46 PM
old man neri's Avatar
Master cylinder leaking brake fluid maybe?
Old 09-20-2008, 09:49 PM
Mike Thomas
Thanks for the responses, folks. Sorry I didn't make it as clear as I could have. First, this is a 1982 SC.
Also, this is the "decorative" floor mats that go on top of the carpet kit, in the driver's side rear seat footwell. The top of the floormat was fine, but the rubber backing was very oily. However, the carpet that the floormat sits on (the "base layer" that is partially glued in) was only a little oily on the carpet side (due to contact with the floormat in my mind), but not on the floor pan side, underneath. The floorpan was dry.
It doesn't seem like a fluid leak would work this way?
1982 911 SC Targa, Chiffon Weiss
2004 BMW 325xiT, Silbergrau
1995 BMW K1100RS, Palmetto Grunen (sold :-\)
Old 09-20-2008, 11:00 PM
RETIRED
Joe Bob's Avatar
Replace or remove the carpets, run the car, see what happens.....could be just crappy carpets that decided to just deompose into their base elements....
Old 09-20-2008, 11:02 PM
+1. I had some old electronic equipment where the rubber "feet" just decided to turn into a sticky grease one day - sounds like it might be similar. If that isn't it, taking out the mats will let you get closer to pin-pointing the source.
'77 S with '78 930 power and a few other things.
Old 09-20-2008, 11:12 PM
The Puff.
Mr.Puff's Avatar
It reminds me of what happens to tape .
'70 CT1B
'11 GTS 300 Super
Old 09-21-2008, 01:40 AM
UNDER CONSTRUCTION!
carrera turbo's Avatar
aw um! the oil goes in the rear of the car
ok sorry throw the mats far from car as they are not helping the resale
ok i agree with the tape thing?
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 09-21-2008, 03:12 AM
Mike Thomas
Thanks all. I'm just going to replace the mats at some point. I have a Lloyd's rear deck mat coming, and if that matches well, then I'll order footwell mats.
Old 09-26-2008, 07:31 AM
Agree. Chuck em out - or keep stompin'! Any chance that oil - could may even be vegetable oil from someone's shopping trip - may have been spilled on the floor in front? Or even motor oil.
Old 09-26-2008, 01:16 PM
Has there been any degradation of the rubber mat? Sound like its either some deterioration or maybe something left under the mat thats liquefied somehow??
Old 09-26-2008, 01:25 PM
do you have a picture of it?
Old 09-26-2008, 01:27 PM
Noel's Avatar
This is what happened to me. Very common.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 09-27-2008, 10:32 AM
FPB111's Avatar
Evidently they are British aftermarket replacements.
2013 991.1 Carrera S Cab
2004 996 Turbo CAB X50 sold
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Old 09-27-2008, 08:07 PM
