-   -   I split my nuts! (http://forums.pelicanparts.com/porsche-911-technical-forum/433381-i-split-my-nuts.html)
JeffO 10-01-2008 01:35 PM
I split my nuts!
In getting ready for my MK cat bypass and Steve Wong chip I had 4 nuts on my cat that would not come off. I purchased the 1 1/2 inch cutoff wheel for the Dremel and went at it. In only 15 minutes all were off. This amazing bit went thru the nut and bolt like it was butter. I am not easily impressed but this cutoff wheel is highly recommended. I used the dremel at its highest speed of 30,000 rpm.
BrokeMyCar 10-01-2008 01:59 PM
Good to know! I have to do that soon.
Babak
gshase 10-01-2008 05:00 PM
I thought this was about a medical issue.
yelcab1 10-01-2008 06:33 PM
That is exactly how I took mine off.
lucittm 10-01-2008 06:38 PM
What will you use for replacement bolts? I am assuming the MK cat bypass (for testing purposes only) does not come with the flange hardware.
Thanks,
Mark
JeffO 10-02-2008 03:25 AM
Hardware is available from SW chips also. All stainless and a small amount of anti seize. gaskets also.
