Would a 265/16 on a 9" Fuchs fit?
Wondering if a 265/45/16 on a 9" Fuchs rim would fit having a 10.2 section width?
Is it a tight fit putting 245/45's on 9" Fuchs on a Carrera 3.2/SC body? For comparison a R1 245/45/16 pm on a 8" rim has a section width of 9.6". Also, a 255/40/17 Falken tire has a section width of 10.2" on a 9" rim. |
Fanatical User
245/45 on 9's is THE fit to have. Most run (or should) 225's on 8's.
I will be running 245 45 16's on 9" fuchs. That extra inch helps solidify the sidewall with a 9" wheel slightly better than an 8" wheel. Of course Johnny Law doesn't want to see this experiment on his roads - only under track conditions - which is where the 9" wheel makes a difference over the 8" wheel. Likely, the only time. |
You are correct sir, 265s on 9s would look like baloon tires and lose the benefit of a straight, stiff sidewall.
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
Schleprock
Keith, The 245/45 on a 9" Fuchs on a SC or Carrera is not a tight fit at all with alot of rear camber. I currently have 14mm spacers behind my 16x9 BBS RS with ET +15mm. There's still enough room that I thought about trying my 928 21mm spacers. Might stick out a little too much........... The 14mm spacers look perfect.
Kevin L '86 Carrera "Larry" |
Sorry I don't have a better pick here at work, but this pic shows the 275s on 9s in the rear and 245/45-16 on 8x16s in the front...
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
assuming that you are looking at one of the Kumho 265/45 tires then yes you are ok.
Once again you will get the most from a tire by using a wheel at the wider end of the spec range than from the narrower end
Correct Bill it is the new K70A Kumos I am interested in. A 9" is near the middle of the recommended rim size of 8.5-10" and it is on the size the measure there section width on.
Also, the section width is very close to the same as a 255/17 that the factory and a lot of other Porsche guys are running on 9" rims. So what is going to perform better on a car that can only get about 3 deg neg camber. A 245 on a 9" rim or a 265 on a 9". This is a about a 9.1" tread width compared to a 9.9". The 245 is a shorter tire at about 24.6 v 25". I am suspect that most get as much out of there rear tires as is possible if the camber and air pressure it right. I would see a 225 that is set up right out hold a 255 that is not. Is it possible that a 225 on an 8" rim could out hold a 245 on an 8" rim if both are set up right and are of the same type of tire? All input is appreciated. Thx |
again treadwidth isn't the only thing to consider, tread shape is at least as important, the static contact patch is approximately an oval, the more elongated the oval is laterally the more grip can be developed that makes a difference in the speed at which peak hp is developed. Taller tires move that speed up, shorter tires move it down. Quote:
yes
