-   -   Sway Bar Bushings Questions (http://forums.pelicanparts.com/porsche-911-technical-forum/433764-sway-bar-bushings-questions.html)
cab83_750 10-03-2008 03:49 PM
I should have done the replacement when I upgraded to ER units. However......
My next project is the replacement of my rear and front sway bar bushings. Can both front and rear bushings be replaced without touching the A-Arms? I just had my car corner balanced and aligned and do not want to spend another greenbacks.
Are polys better than rubber? I thnk my units are the original ones; once I install the new ones, will be see a noticeable difference?
Thanks.
p.s.,
Yes I have searched. On a side note, how does one search the exact string "sway bar bushing" as one whole string? I have attempted to use quotes, double-quotes without success?
Your input would be helpful as it gets cumbersome when you get results gazillion of threads containing just "sway" or "bar" or "bushing".
911st 10-03-2008 06:26 PM
This is my opinion having replaced all my rubber bushings on my 85.
The rear is a pice of cake.
The front bushings on the bar are not hard and doable.
The front bar ends will be near imposable.
However, I think someone said they had done it but I just do not see how it is possable with the shape of the front bar.
If I had spent a fortune having the car corner balanced and aligned, I would just spring for a new through the trunk bar and cut the old bar loops on the a arm out.
Rubber bushs will be the most street friendly. Hard plastic is a bit old school. The newer sway mounts are metal and some type of friction surface or metal bearing links.
cab83_750 10-03-2008 07:45 PM
....The front bar ends will be near imposable.
However, I think someone said they had done it but I just do not see how it is possable with the shape of the front bar.....
I have searched for that link and could not find it (unless you and I are in a wishful-thinking mode).
911st 10-03-2008 09:07 PM
The only way I could see that done is to push one end forward and pull the other back at the same time.
Would require a lot of pressure and or somthing very slippery on the bar (soap or?).
I still dought it can be done.
One other idea I had was to cut off the metal loops. Then weld them to a nut. Drill a hole up form the bottom of the a arm so can be reattached.
Could add washers under it if needed to adjust to keep preload out of sway like done w an adjustable drop link.
cab83_750 03-04-2009 07:47 PM
Just to update and close this thread........
Yes, it is possible to replace the front bar bushings without disturbing the alignment. For clarification purposes, I did it while replacing my revalved-sports Bilstein shocks with HD shocks. While the shocks were out, I decided to replace the front sway bar bushings.
And yes.......the car drives a lot better with new rubber bushings.
Now I need to find out what to do with my sports shocks. Those suckers were too stiff for me on Los Angeles streets........... and, I am very very very happy with the Bilstein HD versions.
