pud pud is offline
Electrical Drain On Battery
HI, i have a 911s 1975 i put a new battery on and start the car run it for a while and turn off, when i go to re start the battery is very low and will not turn starter , when engine was running i removed both battery leads and the engine seemed to lose power end run badly and then stop , can anybody tell me the problem , thanks
Old 10-08-2008, 01:11 PM
Friend of Warren
First off, quit removing your battery leads with the car running. That is a sure fired way to ruin your alternator and CDI module.
You need to get a volt/amp meter and start pulling fuses to find out which circuit is causing the drain on your battery.
Kurt V
Old 10-08-2008, 01:35 PM
pud pud is offline
hi, thanks , the drain happens on the battery when the engine is running ,
Old 10-08-2008, 01:48 PM
Friend of Warren
You need to see if your alternator and voltage regulator are working. Get a voltmeter and check the battery with the engine running. You should see 13.5-14.5 volts at the battery.
Kurt V
Old 10-08-2008, 01:56 PM
pud pud is offline
HI, thanks for the advice, ive got to buy a new exhaust and various other parts can you recommend any good parts sites , pud
Old 10-08-2008, 02:04 PM
Friend of Warren
Uh, Pelican Parts? http://www.pelicanparts.com/catalog/shopcart/911M_catalog.htm
Kurt V
Old 10-08-2008, 02:08 PM
pud pud is offline
ok thanks , pud
Old 10-08-2008, 02:20 PM
