rib rib is offline
rib's Avatar
Leaky Lower Valve Covers
I need to change the valve cover gaskets on my 911. Does anyone out there know what type OEM valve covers are on my car and is it worth up-grading to turbo valve covers?
Porsche 911 Carrera 1986 (Euro Spec)
Steve Wong Chip
Modified Air-Box with BMC Race Filter
SSI with M&K 2 into 1 Muffler.
Old 10-04-2008, 09:29 AM
signature65's Avatar
yes yes and yes, and search search and search.......
Darren
1973 911 T MFI
2005 997 Carrera
2001 Toyota 4Runner
Old 10-04-2008, 09:33 AM
slodave's Avatar
You already have turbo valve covers. If you replace the gaskets, check to make sure the covers are not warped - they still can warp.
Old 10-04-2008, 09:46 AM
rib rib is offline
rib's Avatar
Thanks for the support.
Old 10-04-2008, 10:00 AM
Make Bruins Great Again
Por_sha911's Avatar
-You should have turbo covers already.
-Over-tightening the valve covers will warp them and make them leak.
-Use the gaskets that have a silicone bead (sold by our host).
-Make sure you get all of the old gasket off but don't scar the cover.
-There is a lot of info already out there so it is wise to do a search to find out how to check for warped covers.
Joe
Old 10-04-2008, 08:03 PM
SteveinTO's Avatar
With the valve covers off, take two big sheets of #400 grit wet/dry sandpaper and tape them down on the new granite counter top in the kitchen. Add a little water. Slide the cover around in a circular motion until the mating surface is "shiney." If you're "warped," it'll show. Otherwise you'll have a clean flat surface. Doesn't make much diff what gaskets you use, I like the stock ones, just don't over-tighten the nuts.
If you get caught during the kitchen part, you'll be sleeping under your car.
Old 10-05-2008, 09:23 PM
4flyboy's Avatar
Now that's why I'm not married......................yeah thats why hmmm.
S.
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 10-06-2008, 05:30 AM
Nine9six's Avatar
A thick sheet of glass (coffee table top) might be better. I am not sure of the flatness requirement for granite countertop, but I know glass will meet your needs.
Yes, I am well aware that surface plates are made of granite, but those plates are honed to the desired grade/flatness. They don't fall off the trees in that configuration.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 10-06-2008, 11:40 AM
