Crazy Electrical Issue - long
My car never has a dead battery - no matter how long I let it sit. I went to start it the other day & it was completely dead after sitting just a couple of days. I figured I left a door open, put it on the charger for a few hours and all seemed to be fine. I drove it to a football game 1.5 hours away 2 days later and it started fine. After the game it was dead again. I mean totally dead - like the battery was missing. I got it jumped & made it home. It started several times immediatley after getting home. The next morning totally dead again. Did a series of checks & determined 18 month old battery to be dead. Sears confirmed & gave me a new battery. 2 hours later dead again. More checking - 16.0 amp draw. Removed every fuse & relay and still had the draw. Got out the wiring diagrams & found the starter and then alternator fed by main cable. I jacked up the car & disconnected the started & sure enough draw is gone. Just to double check myself I hooked it back up but now the draw is gone. The car has now sat totally back together for 2 days & starts fine. Any one heard of this before? What could I have done that would make a draw disappear? I had the main cable disconnected at the battery end many times - not sure what difference it made disconnecting the other end. While I am happy the car starts now - I have no confidence that I will not get stranded again as I didn't really do anything. Any thoughts would be appreciated.
1983 911 SC Cabriolet
1999 Durango SLT
20001 Intrepid ES
Dave
Old 10-03-2008, 05:56 PM
the alternator also gets 12V from the starter battery connection. i've replaced alternators for this problem, a few times. early external regulators can stick also. yours should be internal and solid state.
206 637 4071
Old 10-03-2008, 06:12 PM
Thanks JW - I was kinda thinking regulator/alternator - what I can't or won't LOL come to grips with is why did every thing change when I removed the cable from the starter. I had removed the cable from the battery many many times for a couple of seconds to several hours. Is the thinking that the regulator sticks open or closed and sucks the power? Any way to confirm when it is not acting up?
1999 Durango SLT
20001 Intrepid ES
Dave
Old 10-03-2008, 06:23 PM
1986911's Avatar
Dave, a 16 amp draw is pretty significant. If the problem disappears at the starter motor end, I would lean toward the starter motor, specifically the solenoid. If you can duplicate the draw again feel around the starter motor and associated wiring. Something shorting out to the tune of 16 amps is going to get warm if not hot. Remember the solenoid is basically a bridge that connects the battery to the starter motor during start up. If you can get it to repeat, bang on the solenoid and see if the draw goes away. Maybe it did not reset completely after its last start and was partially open. Good luck
Manny
MG---1986 911 TARGA, SSI'S, STEVE WONG CHIP, M&K EXHAUST, ELEPHANT RACING GOODIES + TRU DESIGN CUSTOM FUCHS
1989 930 FACTORY SLANT NOSE -- RARLYL8 EXHAUST, K27 7200, TIAL 46MM, 0.9 BAR SPRING, GARRETSON INTERCOOLER , LEASK WUR, WEGO IV AFM AND NHS BOOST GAUGE.
2012 DODGE RAM 3500 LONGHORN 4X4 "EVERYTHING BUT THE KITCHEN SINK"
Old 10-05-2008, 07:32 AM
Born to Lose, Live to Win
ramonesfreak's Avatar
subs'd
im having similar problem
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 10-05-2008, 08:18 AM
Thanks 1986 - The advise from both you & JW makes a lot of sense. What is curious to me is why it took removing the cable from the starter to "reset" it, because I had the battery end disconnected many times. 3 days now it has been fine - I have only driven one time however. Disconnecting the cable from the starter required me to jack the back of the car up, maybe the angle of the vehicle had something to do with it, though I highly doubt that, or maybe the solenoid stud twisted. Very confusing.
1999 Durango SLT
20001 Intrepid ES
Dave
Old 10-05-2008, 08:26 AM
Manny
+1 I suspect.
Old 10-05-2008, 11:28 AM
Gary H 1978 911 SC
16 amps
You might look for a warm spot somewhere. That 16 Amps should make close to 200 Watts of heat. Get an IR thermometer and check it out.
Old 10-05-2008, 04:21 PM
