cam tower plugs
In tracing a miss in my 911 SC I discovered two lobs on my camshaft were gone. Further checking I found thar the tube that run in the cam tower that furnish oil to the lobs and rocker arm was stopped up . To get the tube out I had to drill and tap the small plugs on the end of the cam towers to get tube out . My question after all of that is does anyone know what the part number for these plugs and where can I buy them. I have not been able to locate any. They are small aluminum plugs about 2 to 3mm around
Thanks.
Old 06-25-2014, 09:28 AM
A more positive seal is to thread the existing cam bar access holes with an 1/8" pipe tap followed by a stainless steel pipe plug (and sealant). Use grease and suction to prevent depositing metal chips in the engine.
Hope this helps.
Sherwood
Old 06-25-2014, 10:24 AM
