Dixie Boost Hooligan
turbo3six's Avatar
Advice needed on repaint of 930
Sikkens? Glasurit? or PPG Global?
Re: 1979 Porsche 930
My paint & body guy was set to do a complete strip to metal, glass out repaint of my 930 with Sikkens Autobase system until it was learned that Sikkens does not have a formula for 304-9-3 Minerva Blue.
Sikkens offered to create a formula based on photos of the paint.
This doesn't impress me as being a very accurate method...?
He has found a formula listed with PPG Global for 304 with no mention of the other two digits 9-3, which I assume represent variances of 304(?).
Will PPG represent an original looking paint? Would Glasurit be better?
What considerations should be made between these paint systems? (Assuming Glasurit has a formula for this code).
72 911 T 3.0 / 73 911 3.0 turbo
74 BMW 2002 TI
79 930 / 84 911 Turbo / 2010 Cayenne GTS
87 911 Carrera Coupe / 87 911 Turbo
94 911 Turbo 3.6 /17 911 Turbo / 18 GT3 / 22 GT3
Old 10-09-2008, 07:13 AM
Each company has their own system for paint. They usually have multiple systems such as lacquer, enamel, polyurethane, epoxy. The look of the paint is most affected by the skill of the person applying and finishing it. The modern two stage systems can give you a lot higher more durable gloss with the clear coat. Are you after orginal look? Do you want an ultra deep show car finish with high gloss? Talk to your painter about your goals for the paint job and they should be able to recomend a good paint.
Old 10-09-2008, 12:35 PM
930 Painting
If I may ask, what does this type of paint job costing? Ball park.....
Tom
Old 10-09-2008, 12:43 PM
crustychief's Avatar
Minerva blue is a great color! Can't wait to see the pics.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 10-09-2008, 12:46 PM
Forced Induction Junkie
WERK I's Avatar
Most high quality shops that either do touch-up or repaints will do something akin to spectrum analysis of the current paint on the car. They then formulate the paint that is going on the car. I had a shop redo my front spoiler after an incident with a family of raccoons. The results were spectacular. If you are repainting the entire car, clear coat is nice if the result is a look of the factory pigment. BIG IF...
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
BTW the factory touch up says "minervablau POR304" on the bottle
Old 10-09-2008, 12:48 PM
304 is the paint code.
The 9 and the 3 have nothing to do with the color itself.
Old 10-09-2008, 12:51 PM
bourgeois911's Avatar
Tom
Got a glass out, chemical strip, no body work quote last week; 7.5 to 8k and I supply all new rubber and glass seals and unbolt all body panels. I also got a quote for 4k that kind of scares me.
Old 10-09-2008, 01:38 PM
I only use Imron clear.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-09-2008, 01:42 PM
turbo3six's Avatar
Thanks the replies...
"what does this type of paint job costing? Ball park....."
$12-$15K... (most of the original rubber seals etc. are in excellent supple condition and will not be replaced.) I did have a quote from the local 'Porsche authorized shop' for $18K. Note: the car needs NO body work or rust repair, NONE.
"Most high quality shops that either do touch-up or repaints will do something akin to spectrum analysis of the current paint on the car. They then formulate the paint that is going on the car."
I understand the need for spectrum analysis...but my understanding is that this technique is used to tint a known formula in order to match paint that has been on the car for awhile and has faded from age and UV exposure. Results are not very accurate unless the formula mixture with metal-flake size and content are known.
"The 9 and the 3 have nothing to do with the color itself."
Curious...why are they on the paint code tag of the car?
74 BMW 2002 TI
Old 10-09-2008, 01:49 PM
nice doggie
Hetmann's Avatar
I got my repaint done with sikkens base/clear about 4 years ago and it has held up very well.
Jerry
78 SC hotrod
02 Mini Cooper S
Old 10-09-2008, 02:08 PM
ZLP ZLP is offline
Low Speed, High Drag
ZLP's Avatar
Mine was done with PPG sealer and paint. I am very happy how it turned out. $15k seems to be the going rate for a top notch shop to do it right these days.
Old 10-09-2008, 02:31 PM
best of luck with the shoot.
My 20 year german paintjob clear slowly and steadily lifts from the new then paint. Kinda bubbled off. Like every year it needed a compounding. It still looks good 20 years later but it's crap.
I'm into using urethanes, not acrylic-urethanes, as much as possible. I just tricked out a C2 rear spoiler. I don't care who makes it.
It looks too good.
I posted some pics today on the auto body site. It's definitely on page 1.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-09-2008, 03:57 PM
Az911's Avatar
Send a message via AIM to Az911
Labor rates in Ohio must be dirt cheap for the shop to be able to quote you such low prices. I think anywhere from mid to high teens is a fair price for a high end paint job.
72T RS look
96 993
Old 10-09-2008, 04:31 PM
I may be misremembering this, but, I think they have to do with:
a. Paint manufactuer (brand) and
b. where the car was painted (which shop).
Don't know if this is quite correct, or what order a and b are in.
Old 10-09-2008, 06:23 PM
