Mitch Leland's Avatar
E-brake dash light...
Howdy,
I want to replace the broken light bulb that activates my emergency warning brake light. Does anyone know if you can go to your local Radio Shack and obtain a similar light bulb that can be solder into the circuit board. Or?
I guess worst case I could un-solder the brake pad wear light bulb since I've abandon that system and solder it back into the E-brake position. Any other ideas out there?
I'm guessing if the dash unit is available it would be expensive...
Thanks,
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 10-07-2008, 05:21 PM
