Good point on the use of cool vs hot, maybe a better way to ask the question is: What's better, a long duration spark with lower voltage? or Short duration spark with higher voltage? Thanks. |
you bumped the idle UP to 920? what was it?
if you dont get spark knock at 5BTDC, i would leave as is unless you want to go to MSD. alot of people on here say the bosch units are better, but when it comes to racing, the MSD are what most are using, like he said above, look at the nascar boys. |
So I only really bumped idle up 40RPMs from stock 86-89 setup. Idle is set in the chip and can be adjusted in 40RPM increments, I simply moved it up 1 notch. Also, the 5deg Advance did help at idle not sure why? I tried 0, -5 and +5 with the +5 giving the best idle for my configuration. Ignition timing can be altered in 0.7 deg increments in the chip. |
I think it's been shown that engines with carbs and/or MFI can produce A/F mixtures on the rich side; sometimes preventing the plug from firing. Higher voltage and/or a continuous spark can reduce the chances of a plug fouling due to excess fuel and/or oil. ECU-controlled engines are much less likely to afflicted with rich A/F mixtures unless the system malfunctions or is way out of whack. The solution is to repair it rather than to fix with a band-aid high voltage box. Quote:
The answer is in the Bosch book or on the tip of someone's tongue on this forum. Sherwood |
The setting of ignition timing in the DME I know very well. The Motronic cars have 3 ignition tables in the chip: 1) for idle 2) for Part Throttle 3) for WOT You can simply set the idle ignition to +5 and not affect anything else. It's far more flexible than simply rotating the distributor in the older cars. You can build ignition curves anyway you wish, it allows you to set timing for a given RPM and load range. In the end I simply altered the idle ignition without affecting PT or WOT ignition. |
Sherwood |
Very funny you ask this. In 2006 I bought the car and it failed emissions at idle with HC=1200 lots of un-burned fuel! Bottom line was that at 800RPM idle with ignition at -3 the car had a lean misfire. Then couple this with O2 Sensor closed loop at 14.7AFR . Luckly, RI is nice and gave me a free pass because of the age of the car. But this still had me worried so I moved idle up to 920RPM and set ignition to +5, then disconnected the O2 sensor, set AFR at about 14.3AFR and then had the test re-run, and the car passed! Also I have NO CAT! but they only tested HC, O2 and CO they did not require NOX for this car. It's nice to know these cars can pass emissions even without the O2 Sensor closed loop and NO Cat. |
The coil for both the CDI and the Motronic setup is doing exactly what it is doing in a car. So the differences for my setup are the ambient pressure and the spark frequency at the spark plug. And with that being said there is a very noticable and significant difference in how both systems act on the bench at higher RPM. Quote:
In case of the Motronic the available dwell time is reduced resulting in less spark energy as well. But again, these effects are not effected by my single-spark bench test setup. So my results reflect some other differences that I believe are spark-duration related. ingo |
| All times are GMT -8. The time now is 01:23 PM. |
