I used the '77 2.7 temp gauge with the 3.2 sender and was getting extremely high temp readings. When I installed the 2.7 sender in the 3.2 engine the reading became normal. |
http://forums.pelicanparts.com/porsche-911-technical-forum/429344-new-3-2-running-hot-maybe.html Scott, is it possible that your gauge is actually from a 74-76 car? I'm pretty sure my '77 gauge is original. If you look at the earlier oil temp sender description in the Pelican catalog, it does say for years 74-76 only: http://forums.pelicanparts.com/uploa...1223736258.jpg I can only guess that the '77 numbered gauge responds like the non-numbered gauges that came in subsequent years. At least, that's how it appears to me.... |
Don, great work.
Wow, it looks like a lot of trouble to change from a 915 to a G50. I didn't realize that it would have been that much work and fabrication needed.
+1 on the super work Don. Tony. |
| All times are GMT -8. The time now is 08:05 PM. |
