Anyone know on what engine this ignition distributor belongs?
I found this in one of my parts boxes. 0 231 169 008. I've looked though all the references I can find including the Bosch Ignition catalog, and can't find anything. Maybe for a Euro engine? The range of neighboring numbers is around a '71 - '73. Takes a vacuum retard pot, which I have, it's just not mounted in the photo.
I post the photo just so someone doesn't ask, "Are you sure that's an 8 and not a 6?" Thanks for any clues....... http://forums.pelicanparts.com/uploa...1223766766.jpg |
maybe a 1973 911T
www.pelicanparts.com/showthread.php?t=374643
also the Tech Spec booklet shows all '72, '73 dizzys same curve |
'72 911e
Thanks to all that responded....
After looking again at the little spec book for the '72 '73 models, I found a line I missed earlier :o ; it shows the 008 as starting with the '73 T, and says they can be installed in the '72 as well, in place of the 003. The '72 E shows an 004, with the '73 E using the 009. Thanks again for the replies. |
I use 0.231.184.004
didn't know it came on '72E. I thought it was only used on '74-'76 Euro Carrera and 2.7 RS, '73 Carrera. I set 10 deg initial BTDC and it totals at 35 deg. Works great for my street engine. It costs brand new $300 at www.********.com Pelican Parts will match any price. Comes new with cap and non-rev-limiting rotor. advance curve on p48 of '72,'73 Tech Spec book ie: this thread has Warren and Sherwood on distributors http://forums.pelicanparts.com/porsche-911-technical-forum/53294-distributor-question.html |
| All times are GMT -8. The time now is 01:08 AM. |
