Anyone know on what engine this ignition distributor belongs?
I found this in one of my parts boxes. 0 231 169 008. I've looked though all the references I can find including the Bosch Ignition catalog, and can't find anything. Maybe for a Euro engine? The range of neighboring numbers is around a '71 - '73. Takes a vacuum retard pot, which I have, it's just not mounted in the photo.
I post the photo just so someone doesn't ask, "Are you sure that's an 8 and not a 6?" Thanks for any clues.......
Jim www.jimsbasementworkshop.com (CIS Primer for the 911) (73 911T (RS look) coupe) (Misc. 911 Parts for Sale) |
maybe a 1973 911T
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
www.pelicanparts.com/showthread.php?t=374643
also the Tech Spec booklet shows all '72, '73 dizzys same curve
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 Last edited by RoninLB; 10-11-2008 at 04:07 PM.. |
gearhead
'72 911e
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Thanks to all that responded....
After looking again at the little spec book for the '72 '73 models, I found a line I missed earlier ; it shows the 008 as starting with the '73 T, and says they can be installed in the '72 as well, in place of the 003. The '72 E shows an 004, with the '73 E using the 009.Thanks again for the replies.
I use 0.231.184.004
didn't know it came on '72E. I thought it was only used on '74-'76 Euro Carrera and 2.7 RS, '73 Carrera. I set 10 deg initial BTDC and it totals at 35 deg. Works great for my street engine. It costs brand new $300 at www.********.com Pelican Parts will match any price. Comes new with cap and non-rev-limiting rotor. advance curve on p48 of '72,'73 Tech Spec book ie: this thread has Warren and Sherwood on distributors Distributor Question
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 Last edited by RoninLB; 10-12-2008 at 05:05 AM.. |
