Putting a stock Blaupunkt amp back in - anyone know these connections? (pic)
Anyone know how to hook this back up to the stock Blaupunkt Reno from an 88-89 911?
The amp is the stock Blaupunkt BQA 80. ![]() Don't quite understand these connections: From left to right: Looks like 4 plug ins for the speakers, got that. Then 12V switched, ground and 12V. Then there's a fuse. But why are there additional spades for speakers? What do these do? Then there's the DIN plug at the far left. Got that. Any clues on how this is wired in? |
911 Africa
HI The
I have been following your requests for help with the antenna from w/screen and the other wiring. I have to do the same soon but it seems there are no reponses to your questions. Please help The the man! I need to know too. Thanks
Andre Marais '58 356 coupe '62 356B T6 cabrio long gone ? 1968 912 long gone 1976 2.7 Targa long gone 1989 3.2 Carrera Targa - Heirloom |
it appears as though there is a diagram label on the amp to the left of the DIN plug. The other connections look like speaker inputs from the stereo if you didn't have the plug.
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
one of gods prototypes
here's what my experience tells me.......
Brought to you by Carl's Jr. |
