-   -   brake light switch replacment (http://forums.pelicanparts.com/porsche-911-technical-forum/435464-brake-light-switch-replacment.html)
mtnfir 10-14-2008 03:02 AM
hey all, My 87 targa recently had its brakelight switches go out. NOt sure if it is one or both, so I plan on replacing them both. They are the two spade connector "narrow" ones. Pelican sells the wide switches and says there is an adaptor for the narrow ones, but I can't seem to locate it on the website. any info would be helpful...or a line on where to get the narrow ones.
thanks
kbruz 10-14-2008 10:27 AM
I'm not aware of an adapter, so I made my own
aj88cab 10-14-2008 10:48 AM
This is another option:
http://forums.pelicanparts.com/porsche-911-technical-forum/399703-brake-light-switch-connector-spacing-problem.html
Good Luck,
Andrew
myamoto1 10-14-2008 11:25 AM
a better solution is to get the BLSAS relay from Draco A50G. Here's another couple of threads for you to check out:
http://forums.pelicanparts.com/porsche-911-technical-forum/434599-one-two-brake-light-swiches.html
http://forums.pelicanparts.com/showthread.php?t=390422&highlight=brake+light+swit ch
rnln 10-14-2008 11:27 AM
I used to add 2 pieces of wire before I got the Arc Suppressor. You might want to read this thread. There are many threads about this. if you want to read more, you can search on "Brake light" or "Arc Suppressor".
http://forums.pelicanparts.com/porsche-911-technical-forum/434599-one-two-brake-light-swiches.html#post4227196
