Need pics of hood mount + fender mount Cibies
I'm prepping a hood for mounting Cibie's and would like to see what folks have done in terms of spacing in mounting them. Is a template available or measurements? Also how they look on the fenders? Do they interfere with the headlights?
Tru6 Restoration & Design |
Carrera 3.0 1975
Not on the hood,but the fender.
![]() ![]() Sorry,no details.......... |
Great color, what is it?!
Carrera 3.0 1975
Minerva blue metallic 1976/1983
here they are on a 911R
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
mounted a lil lower
Thanks Dave, I definitely like the lights set a little further back like on the R. looks like the forward mounting bolt is in line with the top 1/3 of the badge.
RETIRED
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Thanks Mike, this is the variety of pics I am looking for in determining how set back and far apart they should go on the hood.
Please keep'em coming.
likes to left foot brake.
![]() lower edge even with lower edge of headlight |
I would rather be driving
I mounted mine directly in plane with the headlight lens. I used a strip of masking tape between the headlights to mark their location.
![]() You can see the alignment from the side. ![]()
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
perfect, thank you Gentleman!
Sean this may help
![]() And on my car... ![]()
'74 RS 3.0 Replica Porsche 968 Clubsport SOLD '70 911E Bahia Red SOLD '71 911 S/T Replica 2.3 Twin plug BEAST ![]() |
Thank you Cameron! I drill this weekend.
Make sure you use a step drill bit....
I have one, but why is that?
We have installed many of this hood mounted lights... and we were always told to use a step drill bit. So we always used it.
It is probably so you do not ruin the hood, it allows you to drill a small hole then go into the next step hole slowly using one bit, without having to keep chaging the bits. An expert at this might be able to answer this question better... |
