911 1984 Replacement Gas tank.
Hello everyone , this is my first post on this site . Im looking to replace my rusted gas tank in my 911 1984 I hope someone can help out here with my questions , I want to buy new not second hand . Is there any pit falls on buying a re-pro tank ,I had a look inside to see a white plastic filter system plus all the rust . Are these tanks as good as the factory? any comments welcome.
Cheer's , Mark. OZ . Australia. Last edited by cabrio84; 10-29-2008 at 11:01 PM.. Reason: added more information. |
Certified Pre-Owned
Unfortunately, I recommend you source a good used one or cough up for a new one. The repro I picked up was thinner gauge steel, they had used parts from the bottom of an old tank, and I was very unimpressed with the quality of the metal stamping. Keep in mind the factory tank is very strong in a frontal impact, not something I could confidently say using my best judgement about the $400 (US dollars) repro tank.
Did I mention I was unimpressed with the quality of the metal stamping on the repro? Bleeech.
'84 Carrera Coupe |
I think you can take it to a radiator shop to boil out and have it recoated inside and then repaint outside unless its rusted through which is not likely. Seems cheaper, better, stronger, original...?
Post a pic of your car and welcome. |
Happiest when Tinkering
you cant boil it out or reseal it with por or eastwood products because it has plastic in it search for the thread the only way to seal a CIS tank is to cut it open remove the plastic clean it out seal it then weld it back together and pressure test. I have a tank thak would be good for that but have no one in the area that can weld it back together and test.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
Thank you for your welcomed comments Re- my gas tank. The out side of the tank has been bogged and painted over, I may have to look for a second hand one I guess.I wish Porsche would not use that PVC coating as is traps water under it if damaged . Plastic tanks all round!!!!
Cheer's, Mark. OZ, Australia. 84 Cab 911 |
