-   -   stock airbox vs K&N rainshields??? (http://forums.pelicanparts.com/porsche-911-technical-forum/436451-stock-airbox-vs-k-n-rainshields.html)
irl 10-19-2008 07:46 PM
Have been reading a lot about this conversion on early cars but I dont see discussion on real benefits or why to do it. Looking for your thoughts.
Joe Bob 10-19-2008 07:48 PM
Cleans up the engine bay, makes cool intake noises.....
Eric_Shea 10-19-2008 07:49 PM
I believe there was a study done and they saw no additional gain. Stock is fine.
Bart_dood 10-19-2008 08:57 PM
I used to be a real K&N fanboi years ago, however after reading various tests, not on airflow but on particle ingestion I steer clear of K&N's now.
They have some good applications such as race engines which will wear out rapidly no matter what air filter is used. However on road engines which are expected to have a long lifetime these days, they simply let too much small crud through, grinding your compression away..... Just my 0.02C
signature65 10-19-2008 09:21 PM
There have been many posts on this subject......K&N's VS Stock with and without spor mufflers.....etc. Basically when it came down to the numbers the stock airbox makes more HP.
Eric_Shea 10-19-2008 09:27 PM
I'm with Bart... K&N = Bad. Took out the MAF on my ML320 a few years back. Did a little research since then and found the stock paper elements work much better.
