What is the best fuel pump for Weber / PMO Carb
Hi,
Any feedback on good aftermarket fuel pump that will supply the right pressure for Weber or PMO 40 mm ? (Going with carb on a boosted 2.4S, for street)
Where did you mount/install it ?
JD
65 coupe, Dolphin gray #1506
70S coupe, Blood orange #1436
R Gruppe #647 ; S Registry #1666
Old 10-21-2008, 06:10 PM
I think with any pump you should use a regulator. The venerable Holley Blue ( or even a red ) is a decent reliable choice, and I've mounted one in the factory style location on the front crossmember ( vertical orientation ). The Holleys are loud though.
In my current car I have a billet SX pump and a Mallory regulator. The SX or Mallory pumps are much quieter than a Holley.
Cheers,
Earlysport
_____________________________________
69 911E, 69 911E RS Rep 3.0L Hotrod, 77 930
IROC REP 3.6L SOLD, 968CS SOLD, 987 Boxster S SOLD
Old 10-21-2008, 06:38 PM
abit off center
cgarr's Avatar
We use the Carter 4070 Rotary Fuel pump, They run right at 4 psi, no regulator needed and are only about a hundred bucks.
It should be mounted up by the tank so it pushes the fuel along with an inertia shut off switch.
Craig
G2Performance
Old 10-21-2008, 06:57 PM
myfast911's Avatar
fuel pump
i am running a peterburg fuel pump,runs at 4lbs, cost 125.00,and it fits just right where the old one goes.under the gas tank.
Old 10-21-2008, 07:04 PM
avendlerdp's Avatar
DO you already have a fuel pump from the mfi setup? If so, you can use it if you use a regulator and a return line.
1972 Porsche 914 Project
2000 BMW M5
1973 Aermacchi 350
Old 10-21-2008, 09:09 PM
(the shotguns)
berettafan's Avatar
bought my pierburg from Richard Parr at PMO. Mounted it in the front and works fine and dandy.
Craig what's an inertia shutoff switch???
Old 10-22-2008, 06:05 AM
abit off center
cgarr's Avatar
Its a G force switch which cuts the power to the pump if your in an accident or roll the car. We just pull them out of old Ford cars. Its wired inline to the pump.
Craig
G2Performance
Old 10-22-2008, 06:49 AM
(the shotguns)
berettafan's Avatar
any potential issues with an ax car on sticky tires?
Old 10-22-2008, 06:56 AM
abit off center
cgarr's Avatar
Nope, we run hard without any problems, We have ours mounted in the smugglers box with the fuel pump. Whats nice, you can test it and then reset it with the button.
Craig
G2Performance
Old 10-22-2008, 07:01 AM
Carrerax's Avatar
Ok, I have the same question about a fuel pump for a 70T with solexes. My pump is original and has sat for 20+ years. What is my best option? Sorry for the hijack..
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
Old 10-22-2008, 07:33 AM
That '70T has Zeniths, not Solexes,...
Disassemble and clean that original NLA Bosch fuel pump to start with. If that doesn't do the trick, use the Pierburg.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-22-2008, 09:01 AM
Carrerax's Avatar
Steve,
You are correct. I was actually researching them and ran across a thread on Solexes and my ADD kicked in and it went down hill from there. Thanks!
Old 10-22-2008, 10:21 AM
I've been using a Carter for 2 years now and it works great.
Old 10-22-2008, 11:00 AM
AutoBahned
RWebb's Avatar
the Bosch pumps are very high quality - the only ones not to use are super high presure mfi
Old 10-22-2008, 11:34 AM
I have a Mr. Gasket pump and a Holley pressure regulator. Pump works fine and fits great in the original pump location. It is a bit loud but makes me feel like im starting up an old Ferrari
Old 10-22-2008, 11:35 AM
RWebb,
If you use the PMO Fuel Block that maintains the 'return line' for the fuel. Why won't the high pressure MFI pump work?
Regards,
Tom Ching
69 911E
Old 10-22-2008, 01:10 PM
He,he.
I've been using a Facet with no regulator for about 10 years.......but I promise that when it pukes I'll get one of them hi-zoot jobbies. That constant clicking has begun to bother me.
JPIII
Early Boxster
Old 10-22-2008, 01:29 PM
Good ! I don't really know the condition of my original MFI pump and I want to have 100% reliability with my new ride. Does someone is using the Bosch MFI fuel filter or should I change it also. Does the pressure drop will be to high if I use a 4 psi aftermarket pump ?
Thanks !
JD
Old 10-22-2008, 07:02 PM
AutoBahned
RWebb's Avatar
Originally Posted by Tom C. View Post
RWebb,
Regards,
it might - that is a lot pressure to bleed off tho - the cis pump works great
see if Steve responds again or if you have pmo's, fax richard parr
Old 10-22-2008, 08:50 PM
