-   -   Problems with Rev Counter With MSD ?? (http://forums.pelicanparts.com/porsche-911-technical-forum/436618-problems-rev-counter-msd.html)
P Moore 10-20-2008 04:54 PM
HI,
Just wondering is my Tach Clock not working because of my MSD unit,
Im not sure if it was working before hand as when i got the car i took it all apart for a rebuild.
I have the following installed:
MSD 6AL
The Blaster Coil
MSD's Tach Adapter
and a Pertronix thing to replace the points,
I rang MSD for to confirm their wiring diagrams and so far the starts no problem !
But i have been informed that "some wire " should have gone to the rev counter,
Is this correct ???
Im still no wiser !!:confused::confused:
Sorry its a 1975 Targa.....
P Moore 10-21-2008 12:40 PM
Anyone on this ?? Have i to have a wire coming from the msd to the Rev Counter ??
jtkkz 10-21-2008 07:36 PM
MSD 6AL usually do not work with the Tach..
The Tach will need to be re-calibrated... www.nhspeedometer.com
I have sent 2 of my tachs already to them for re-calibration when I installed MSD 6AL.
RoninLB 10-21-2008 09:53 PM
usually guys do the msd install with a good tach. If the tach screws up after install guys get the msd tach adaptor and fixeroo. Maybe borrow a Bosch or Permatune unit and flip w/msd for test.
I even has radio noise with resistor spark plugs. The msd noise unit fixed that.
JohnJL 10-21-2008 11:39 PM
I found on a 71 that my tach started working fine when I removed the adapter...try that.
P Moore 10-22-2008 04:42 PM
Emmm Intresting.. Could someone tell me which way they wired up their units ??
How does the signal get from the MSD to the Rev Counter at the Dash ??
I think i might be missing some wire/signal here,
What i have is the ALWAYS ON POWER coming from the starter to the BIG RED wire on the 6AL unit,
Then the small red on the same unit i have switched power, (comes on with key)
Then to the TACH Adapter and to pertronix, i rang MSD for this bit but in only took minutes to wire up,Red to red / white to white, and then the pertronix branched into these, i forget their colours, so im not sure how the rev counter would get a reading from my set -up....
Am i at fault here ????:confused:
JohnJL 10-22-2008 05:16 PM
Try leaving the adapter out of the equation and just connecting the purple/black signal wire from your tach to the coil - post or to the MSD box white wire and see if either of those work for you.
RoninLB 10-22-2008 08:54 PM
member Raynald from Canada drew this up a few years ago
http://forums.pelicanparts.com/uploa...1224734042.jpg
P Moore 10-22-2008 10:12 PM
AHhhhh im mising that MAUVE TACH wire, sure it must be there somewhere...
I dont think there is nothing special with the red wire connection coming from the OLD CDI PLUG i think its only switched power....
