-   -   Can I use a 964 dizzy in a 3.0 motor? (http://forums.pelicanparts.com/porsche-911-technical-forum/436697-can-i-use-964-dizzy-3-0-motor.html)
matty74 10-20-2008 11:58 PM
I am doing another top end rebuild and want to go twin plug.
Can I use a 964 dizzy in a 1978 3.0 sc motor?
what modifications need to be done for this to work?
Steve@Rennsport 10-21-2008 12:27 AM
Matt,
You must install a 964 crank gear to use the 964 distributor in your SC so that it rotates the correct direction and match the pitch of the gears.
matty74 10-21-2008 01:24 AM
so I assume I have to split the case to install the crank gear?
