Case Saver Installation
Pelican Parts has a Case Saver part # RP-102 10 mm x 1.5 I.D. 14 mm x 2 O.D. which I need to place in my 911L magnesium case, replacing the threads holding the bolt which fastens the engine to the transmission. After drilling out the pulled-out threads so that a 14 mm x 2 tap will work, do you need a special tool to install the Case Saver?
Old 10-23-2008, 01:11 PM
abit off center
cgarr's Avatar
Just use a 10mm bolt with a nut threaded on it as a stop to run the case saver in. Make sure to use some loctite.
______________________
Craig
G2Performance
Old 10-23-2008, 01:46 PM
