Repaint w/ color change. What about VIN sticker in the door jam?
Hey there,
I approaching the paintwork on my '77 project car and a paint color change will be involved. I'm wondering what I should do about the VIN sticker on the drivers side door jam.
I've looked at many pictures of 911's over the years that have been repainted. Some tape over the VIN sticker and leave the sticker and a small area around it untouched with original paint. Others remove the sticker and paint the entire door jam.
I'm undecided about what I'm going to do.
Pros for leaving the sticker:
-Leaving the sticker is nice for originality, though my project car is far from original.
-One of the VIN spots on the car.
Cons for leaving the sticker:
-New paint (especially with a color change) looks much better without the sticker and a bit of original paint exposed.
-Possibly will allow the new paint edge to chip.
What do you guys think? Keep the sticker or remove it?
Thanks for the help!
Old 10-14-2008, 05:49 AM
robmog's Avatar
keep the sticker, its only original once.
bob
1972 E pos
correction: expensive pos
someday....
"shut up and drive!"
Old 10-14-2008, 05:59 AM
John Brandt's Avatar
I've always heard Porsche can supply a replacement.
Old 10-14-2008, 06:51 AM
As I read your post, originality is already out the window to the degree that the VIN sticker won't make a bit of difference. I'd say remove it, do a quality repaint, and check up on the Porsche reissues if you truly want to have a sticker.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 10-14-2008, 06:59 AM
robmog's Avatar
if your sticker is silver there is no replacement.
the new stickers are black.
however ossiblue has a good point re originality
bob
1972 E pos
someday....
Old 10-14-2008, 07:07 AM
The sticker I have is black.
Old 10-14-2008, 07:11 AM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
At times I encounter the same situation. On the cars that I want to keep the sticker I'll mask the it off and paint right up to it with my basecoat. Then I'll unmask it and clear right over it. This way you don't have that ugly rough edge around it or a mismatch of the color around it.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 10-14-2008, 07:58 AM
Slippery Slopenose Victim
SXSMAN's Avatar
I also asked some time ago .
Info here .....Does anyone make repro VIN decals ....
SxS
Old 10-14-2008, 08:34 AM
AutoBahned
RWebb's Avatar
if a plate then drill out the rivits
if a stuck on sticker then mask well - press down - use caulk at tape edge - then wipe off excess
spend time spent with magnifier, sharp blade and thin brush up to limit of your sanity
Old 10-14-2008, 11:14 AM
175K911's Avatar
Scott- on one of my other cars, when the left side got hit and new pieces had to be welded in, the body shop was able to lift my old VIN sticker off and reapply it to the freshly painted new door jam. The work was so darn good that it's almost impossible to tell it isn't original.
Ed
'86 911 Coupe (endless 3.6 transplant finally done!)
'14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one)
'97 BMW 528i (the sensible car, bought new)
'12 Vintage/Millenium 23' v-nose enclosed trailer
Old 10-14-2008, 01:34 PM
Happiest when Tinkering
gsmith660's Avatar
When I did my repaint I went to PCNA for a new sticker and they are NLA for older cars mine is a 76 I got one from a fellow pelican with instructions do a search I cant recall his name right now I have not found a punch that will work for the vin though there was a debate and most agree that it is not a true vin location but a emissions sticker or some such thing, if you get his which look pretty dang good and a punch to do the vin please let me know.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 10-14-2008, 04:52 PM
gsmith660's Avatar
Robmog is the man. they look real good hi Bob still looking for a punch.
Old 10-14-2008, 04:54 PM
4flyboy's Avatar
Kevin knows...
+1,
I've seen Kevin's work and I tend to listen to him.
S.
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 10-14-2008, 05:17 PM
Vin Decal
Try Stoddars local parts deck I picked up a replacement Vin decal for the B post in black for my 83 a few years ago.
LM
83 SC
Old 10-14-2008, 07:49 PM
gsmith660's Avatar
Bob IS the man he is sending me a punch and did I say his stickers were awsome looking!
Old 10-15-2008, 04:45 PM
robmog's Avatar
thanks
bob
1972 E pos
someday....
Old 10-15-2008, 06:03 PM
Carrerax's Avatar
Rob, I received my sticker and I must say it looks awesome. The problem is that I cant find a good picture of an original one (1970) so I can make mine correctly. does anyone have an actual picture of one? I did try to search but no luck. Thanks!
1997 C4S stock...ish
1970 911T Restored Hot Rod....Sold
http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html
Old 10-24-2008, 06:07 AM
gsmith660's Avatar
Here is mine it was a replacement from stoddards when I did my first restore in 92 hence black instead of silver.
Old 10-24-2008, 06:15 AM
I just when through this on my old Datsun Z. I took some time to carefully make a perfect covering surface with masking tape when I just did a repaint on my Z.
Removing the stickers to me was NOT an option or even consideration. The Datsun stickers are cool as well due to the Japanese \ Kanji writing on them and also French, so I was going to preserve them no matter what.
I would do the same on my Porsche as well.
Prep:
Primed:
Painted:
Regards - Yasin
Old 10-24-2008, 06:17 AM
robmog's Avatar
carrerax
picture above is correct re # locations.
only wrong color
bob
1972 E pos
someday....
Old 10-24-2008, 06:33 AM
