K&N w/ watershield installation question
When i bought my 71T, it came with a awful chrome stock air housing and I recently bought a pair of K&Ns to install on my webers. I have read the posts on no real perf difference, I just want the sound and the look. I dont drive it enough to really do a lot of damage. But I have an installation question because I never get decent directions.
Once I remove the stock top air housing, I am left with the stock base mounts with the clips on the sides. Once I remove the nuts to release the old housing base along with the air horns......Do I place the new K&N filter base down with on top of the carb with the gasket and then put the stock airhorns back on top on the new K&N base? |
yes.
Sherwood |
Yes, and buy the vapor kit with hose from Richard Parr at PMO. His phone is
310-394-0088. It will really clean up all the evaporative emission control hoses in your engine compartment that used to attach to the stock air cleaner. |
Thanks,
This site is really amazing, Im going to post the step by step photo process for others in the future. |
grease the filter gaskets heavily and keep it oiled
ronin can u explain that more for me, thanks.
the wheel bearing grease on the rubber seal at either end of the filter will keep dirt from sneaking by. At the risk of being trashed about the K&N filters allow me to say that I can never find any dirt inside the filter carb top area. Some would argue that routine lab tests on a K&N filter is inadequate. That the oil on a running vibrating engine creates a vapor that captures any oil trying to pass through. If you buy into that you'll understand that oil is vey important to K&N operation. I re-oil once a year or after one of my big rides which may be 15-20,000 miles. Another pelicanhead posted to re-oil every 10,000 miles. http://forums.pelicanparts.com/porsche-911-technical-forum/404330-k-n-carb-filters-aok-confirm.html |
Thank you, one more question. Is there anything I do to seal the paper gasket underneath the new K&N base or does it just lay as is.
lay as is |
Cleaned & oiled my K&N last night. K&N recommend cleaning much less frequently than 10,000 miles, unless you're running in a very dirty, enduro-type environment (a standing recommendation is "clean if you can't see the filter mesh").
This is probably because it filters better when slightly dirty Quote:
http://www.knfilters.com/filter_facts.htm#SLIFE |
2nd - it is not the dirt you see that is a problem; it is the very fine abrasive particles that are too small to be seen with the naked eye it's too bad they don't make paper filters for this appl. ... |
| All times are GMT -8. The time now is 05:58 PM. |
