-   -   3.6 cuts out NOT DME relay (http://forums.pelicanparts.com/porsche-911-technical-forum/437334-3-6-cuts-out-not-dme-relay.html)
johnsjmc 10-24-2008 09:51 AM
I have a 3.6 in an early car. It,s been running fine for several years but due to a knee injury was not driven for last 2 years. I now have an occasional engine cut out while driving. It lasts a fraction of a second ,tach bounces and will stall if idleing when it happens. I have replaced the DME relay because you can feel it click when this happens. No change.
Some reading here suggested the DME itself might be rebooting due to interferance so I changed the caps and rotors. Runs a little smoother but no change to the cutting out.
I opened the DME and looked for bad solder joints and reflowed a couple suspect but no change,I was installing a Steve Wong chip anyway so I had the box open.
As the flywheel speed sensor on the 3.6 detects motion and activates the pump I then changed the flywheel sensor with no change. I have since adjusted the space between the sensor and flywheel (.8 mm) with a washer glued to the old sensor to set the distance. I had thought it fixed the problem but it,s back Maybe not as bad but still happening. The adjustment seems to be as close as I can get it to the flywheel without modifying the holder Any fresh ideas?
Formerly Steve Wilkinson 10-24-2008 10:43 AM
I had the same problem in my modified '83 SC--PMO carbs, no DME. While driving, the engine would occasionally die for anywhere from half a second to four or five seconds. Funny thing was, all the instruments also went to zero briefly.
The advice I got here was to change out the electrical component of the ignition switch--has nothing to do with the key/tumbler/lock, just the cassette that plugs onto the back (i.e. toward front of car) of the ignition-switch/steering-wheel lock unit.
I did so--it's a real bear to get at--and haven't had the same problem since. Granted, I've only gone a few hundred miles since then, but the car has run just fine. Apparently those switches control most of the electrical circuits in the car, and they are notorious for going bad and creating a vast variety of electrical ailments, from intermittent ignition failure to suddenly-on headlights to you name it.
As I remember, there's a couple of pages in Wayne's 101 book on how to effect the change.
RSstop 10-24-2008 11:13 AM
I had the same split second cut-out on my 91 C2 only in right corners at the track. Almost like the fuel pump lost power for a 1/4 second. I found a bad spark plug wire that was loose and grounding on the header. I replaced it overnight and returned for the 2nd day of the DE. No return problem in 3 years since.
There was another post recently with a bunch of other things to check for. It might have been on the 964 board.
Lyn
Paulporsche 10-24-2008 12:26 PM
Are these the units that are connected w/ the dome lights? Maybe you have a bad connection or failing bulb there.
