sun roof delete ?
Hi all does any one have pix of sunroof removal pan and all .Ive started the job drilled out spot welds up front .Its the sides inside the pan that is the challenge.Got things loose up front thus far.The plan for now is to weld in the sunroof.any help most appreciated. 77 911.
UNDER CONSTRUCTION!
Do a search on here as jsut a few days ago i ran across a thread on just this, im doing the same thing on a 77 as well, so ill see if i can find it again,
glad your first post some pics. ed Sunroof Removal/weld Shut
Sometimes the first thing that comes to mind should be the last thing that you do!
I saw that post quite interesting. Iam looking for more detail from the underside
