need help, body dimention and door gaps
preparing to restore a 68 targa and as i am buiding the rack to keep it in place , i would like to make sure its at the right place before i start welding
had been looking all around but cant find anything
I need the targa to windsheild frame dimention as well as the door gap, is it the same all around and 4mm, 5mm, can you tell me,
even my factory manual does not show the two i really need
thanks in advance
Yves
9140431696 painted, with wheels and brake , with all elctrical working , engine in assembly soon to be driven
011850275 911S soft window targa next in the garage
2000 S4 stage 2
660R stroked
Old 10-27-2008, 07:07 PM
Mr9146's Avatar
ALL the gaps on the car should be within 3-5mm.
With Targas, there is no set roof gap because the roofs are all piece of garbage that don't fit for ****e. With Targa tops you just do the best you can with the latch adjustments.
Old 10-28-2008, 09:02 AM
