-   -   E-Grind cam specifications (http://forums.pelicanparts.com/porsche-911-technical-forum/438389-e-grind-cam-specifications.html)
Brent Lineker 10-29-2008 05:07 PM
I just got back from machine shop to get my specifications for my cams.I had e cams put in for a 2.7 rebuild with mahle RS 90 mm p&c's webers,ssi's and sport exhaust.The specifications are as follows.These were reground from my CIS cams
-Intake duration 219 at .05 valve lift .420
-Exhaust duration 212 at .05 valve lift ..396
I can't find these specifications on any chart.Does anyone know if these are indeed e cams or in fact something milder.
emcon5 10-29-2008 09:13 PM
According to John the Camgrinder's chart, that doesn't match any stock cam.
http://www.drcamshafts.com/911profilesprint.htm
The E should be 230º @.050"with .405"lift on the intake and 222º @.050"with .393"lift on the exhaust.
Tom
Brent Lineker 10-30-2008 05:09 AM
That is the same chart I was looking at too.The machinest told me that the factory specs are the ones he gave me,but I can't find where to look for factory specs.
moneymanager 10-30-2008 07:04 AM
Dumb question, bit off topic. I understand lift and duration, but was does the "at .050" spec tell me? Thanks
emcon5 10-30-2008 07:11 AM
It is just the duration starting and stopping as the cam passes at .050" of lift. It is a simple way to make apples-apples comparisons between cams,as some manufacturers list seat duration, or don't mention what they are talking about. For example, Elgin http://www.elgincams.com/c-por2.html "Our duration figures are the end of the clearance ramp"
Tom
moneymanager 10-30-2008 07:36 AM
Thanks Tom, very helpful.
RoninLB 10-30-2008 07:36 AM
http://forums.pelicanparts.com/uploa...1225380993.jpg
Brent Lineker 10-30-2008 03:49 PM
They gave me timing specs of- intake opens@29 btdc closes @39abdc
-exhaust opens@39 bbdc closes@19 atdc
RoninLB 10-30-2008 04:42 PM
ok
those 1970/71 valve timing numbers are incorrect says Allan Caldwell.
the 1969 and the 1970/71 E cam are same so says everyone. The yellow was circled by Stoddard.
http://forums.pelicanparts.com/uploa...1225413722.jpg
sorry for my confusion
