-   -   Caliper rebuild, rotor and oad change (http://forums.pelicanparts.com/porsche-911-technical-forum/438512-caliper-rebuild-rotor-oad-change.html)
Daviboy 10-30-2008 01:18 PM
Just whipped off the front wheels, changed out the rotors, stripped cleaned and rebuilt the calipers, threw in some new pads, bled system and tested. Easy total 4 hours and solid brakes on completion. Another wee project bites the dust.
ruf-porsche 10-30-2008 06:58 PM
Hey I did the caliper rebuild on my 82 SC Targa this past summer. Replaced the steel pistons with stainless steel pistons. Should be good for another 26 years.
burgermeister 10-31-2008 12:51 PM
Ruf-Porsche, where did you find pistons for your calipers? The only ones I've seen advertised are for the aluminum "S" calipers. Or do you have said calipers?
My pistons are a bit pitted (though still leak free for now), but I am not anxious to spend $600 on 2 new calipers to get that fixed.
Flieger 10-31-2008 01:36 PM
Narrow A calipers are the same design as S calipers but made out of steel. Shouldn't the S calpier pistons fit the A caliper?
burgermeister 11-01-2008 07:19 AM
Pelican does not list them as fitting. If they do, that would be dandy. I have wide A calipers I believe (I have an '88), but I would think (dangerous, that, where Porsche is concerned) that the pistons would be identical, and the caliper got wider.
ruf-porsche 11-01-2008 10:35 AM
My calipers are also "A" calipers. Got my stainless steel pistons from ZIMS. Piston were $32.00 each so for 4 pistons they came out to $144.00 plus the price of a calipers rebuild kit.
burgermeister 11-01-2008 12:56 PM
Thanks much.
Daviboy 11-03-2008 08:17 AM
Brakes are great now big difference even though old pads were 50% and only one rotor 3 thou under, although the rebuild has eliminated the pull to the right which was from the outside piston on the passenger side.
