luvndasun's Avatar
Drill or Dont Drill (ITBs)
Hi All,
If I want to install the ITBs that I have, I'll have to drill and tap my intake manifolds in order to provide a place to monitor the intake perssure using a MAP sensor. The intake pressure port will have a tube routed to the MAP sensor manifold. You can see the MAP sensor manifold in the first picture. The second picture shows about where I think is the best place to drill the intake manifolds to pull the pressure signal from. (sorry about the pic quality). Before I make the irreversible modifications, I wanted to see if some of the ITB gurus out there would chime in and lemme know if I am on the right track or if there are any better alternatives. Thanks in advance for the advice. Oh yeah, the engine is a 3.0L.
Royal Purple/Lilac, Signal Orange, Guards Red
Old 10-31-2008, 11:57 AM
1984-911 M491
Trog's Avatar
My PMO ITB's locate their vacuum connection as shown below:
I'm confident it would work if you drilled/tapped the manifold flange.
Trog
1984-911 TLC......SOLD
Old 10-31-2008, 12:07 PM
Navin Johnson
TimT's Avatar
No need to drill anything. Use whats provided on the throttle body
'69 911 GT-5
'75 914 GT-3
and others
Old 10-31-2008, 12:15 PM
1984-911 M491
Trog's Avatar
It would appear that he is missing the vacuum ports on the throttle bodies... at least I can't see them in the photo?
Old 10-31-2008, 12:20 PM
Those already have the vacuum ports below the throttle plates, as desired.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-31-2008, 12:24 PM
Navin Johnson
TimT's Avatar
The TWM ITBs gang together the vacuum in the casting
'69 911 GT-5
'75 914 GT-3
and others
Old 10-31-2008, 12:26 PM
Originally Posted by luvndasun View Post
Hi All,
Anywhere below the throttle plates will be fine; you are on the right track.
I've seen those TWM ports clog up with carbon, depending on what cams you use, so I like to install separate fittings to each cylinder runner.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-31-2008, 12:27 PM
I would rather be driving
jpnovak's Avatar
I too have TWM throttle bodies. I could not get a clean MAP signal using the single port provided by TWM. It was so bad you could see the individual pulses of the center (#2 and #5) cylinder in the datalog. I sm not sure if this was due to the size of the port or the way it was connected across the runners.
I capped it and drilled one hole in each manifold runner. I then have six vacuum lines that Tee into a manifold similar to the one in the picture. I packed the manifold with open cell foam and have a rock-steady MAP at idle. I have not noticed any lag in response from the foam.
btw, I drilled small holes. I think bought brass hose connectors that are barbed on each side. I milled one side down in the lathe and then epoxied into the hole. On the back side I smoothed with a die-grinder. On my weber manifolds there are small circular flats midway on the height. They are on the outside of the manifold. This was my port location.
Old 10-31-2008, 01:01 PM
luvndasun's Avatar
Thanks for the help, I feel better about doing this. I'll look into using smaller fittings. That PMO setup is sweet.
Happy Halloween.....bwhahahaha!
Old 10-31-2008, 04:36 PM
