checking bad grounds
what would be the best way to check for a bad ground ? (meter or visual)
Test light or a meter. With a meter just measure the resistance, it should be 0 ohms or dang close to it. Visual works only if there is something really corroded or broken.
Test the resistance between places that should be ground (like a wire connection or whatever) and someplace that you know is ground, like the negative battery terminal. While observing the resistance, vigorously stress/shake the connections and wires between that location and ground looking for a change in resistance. Most multimeters have a beap feature that makes a sound when the two leads are in "contact" through a circuit, you can use this to just listen for the beap to stop while you wiggle, instead of watching the readout. Keep in mind that the contact resistance of the meter will probably read around 0.1 ohms when the two leads are connected through a wire, take this as zero. A broken circuit will read some very large resistance (many mega-ohms) or the gauge won't read at all. Hope that makes sense and good luck.
take them off and clean them.
A single strand of wire from a group of conductors will produce zero resistance when checked with an ohmmeter. And that single conductor strand may create enough resistance to prevent the circuit from working properly.
An ohmmeter isn't the most appropriate gauge to measure grounds. How could you accurately measure a suspected ground connection with an ohmmeter? BTW, ohmmeters don't like live circuits. It can let the smoke out of the meter. Use a digital multimeter and check the voltage drop (the amount of voltage loss between two points in an active circuit. Connect the voltmeter leads to either end of the circuit to measure (not including the load), then switch the circuit ON. Voltage drop should be typically less than .1 volt. Sherwood |
So maybe a megger would be better but not a lot of people own one. Hence the shaking of the wires.
Then stop thinking about continuity problems in your chassis. |
Like others have said clean the grounds. There aren't that many grounds on your carrera and it will probably take you more time to check them than to clean them.
Especially the hidden connection from the battery negative to the body, its well hidden. Then there is the one from transmission to body..................... Don't just do grounds, all connectors are prone to corrosion. Carefully disconnect any you can find, clean, and use dielectric grease, especially on the 14-pin. Ensure that the relays have tight pins, sometimes they get tired and need to be spread a little with a very thin blade. Use dielectric grease. :cool: |
And it wasn't limited to cars |
the problem with this is if it is a low current circuit, if just a few strands are connected as you said and the resistance is 0, it can still show .1v and you think all is good. |
SmileWavy |
i assume he is not asking WHERE all the grounds are. |
it still would not hurt after all is cleaned to go ahead and make some resistance checks just to make sure. |
I was giving him advice based on my experience looking for a bad ground and made the assumption that he is working on the carrera in his signature. -Shawn |
Voltage through resistance equals HEAT!!!
Simple to check for warmer than surrounding connections. In an extreme case....you could use a thermal imaging device. And as my instructor said almost 50 years ago....if you are not willing to lick a connection with your tongue....it's not clean enough for electrons!!! Bob |
keep it simple,...disconnect/clean/reassemble all ground connection points...period. You should see 0 ohms, bud (essentially).
what is your "grounding" concern, BTW? (symptomatically, that is..) Best, Doyle |
| All times are GMT -8. The time now is 08:09 AM. |
