Backfiring on Decel
This is my track only 85' Carrera.
I want to know if I should worry about my car backfiring.
It happens every time I let up on gas at high speed, around 100mph +.
It's always one very loud pop.
Your input would be greatly appreciated.
Thanks,
rgd
85' 911 Coupe: Rebuild complete.
Old 10-30-2008, 02:22 PM
Bart_dood's Avatar
I'm not an expert but I believe whats happening is this: during full throttle the DME injection runs on the rich side of things as it guesstimates the air flow etc, then when the throttle is snapped shut the DME shuts off injector flow, so now you are getting air flow with no fuel, the air hits the hot exhaust with some fuel vapor build up (from the full throttle) in there and its very hot so it pops due to ignition.
1997 Boxster SOLD
1999 R1100S SOLD
1988 Carrera 3.2
Old 10-30-2008, 02:30 PM
From what you are saying it doesn't sound like anything to worry about.
Thanks for your input!
Old 10-30-2008, 09:37 PM
19 years and 17k posts...
azasadny's Avatar
I had some backfiring on deceleration and I put a can of SeaFoam in the gas tank and after about 100 miles of driving, no more backfires... worked for me.
Art Zasadny
Learning the bass guitar
www.ford.com
Old 10-31-2008, 04:17 AM
this happened to me on the track....
very likely the idle control switch is not staying "off"
this is bear to adjust but straight forward
Old 10-31-2008, 04:37 AM
ruf-porsche's Avatar
Exhaust Leak?
Old 10-31-2008, 06:04 AM
Monkey Butt Forespin
84_Carrera's Avatar
My '84 does it with the muffler bypass. Mine's set to run rich anyway (+6% fuel), and with the muffpass it's very noticeable. I've replaced all of the gaskets at the heat exchangers in the past year, and I'm running coppers on the cat & muffler flanges.
I only have very light popping & only occasionally with Ben's muffler.
Fred Hurder Jr
For Tech Questions:
'84 911 Carrera Cabriolet (US)
Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler
22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks
ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars
Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans
Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Old 10-31-2008, 06:28 AM
There are two main causes for backfire. The first is an exhaust leak. The second is unburned fuel off throttle.
The unburnt fuel should be taken care of in an '85 because the ECU should kill fuel into the cyl off throttle. Unless you keep your foot partially on the throttle or you have a leaky injector, this shouldn't be the problem.
Old 10-31-2008, 07:33 AM
Senior Member
Superman's Avatar
Exhaust leak is the usual culprit. However....this generally causes simple popping, not big explosions. In the olden days, we would sometimes turn the ignition off for a moment while coasting down a hill in gear. When we turned the ignition back on, there was a nice BANG.
Mocha 1978 911SC. "Coco"
Old 10-31-2008, 08:36 AM
wannabee wannabee
WIL84911's Avatar
Had a similar loud pop before adding 911chips.
99 C4 - (let's try this once more)
07 Cayman S - sold 11/17 (not the same)
84 Carrera - sold 3/16 (geez what have I done!)
Old 10-31-2008, 03:23 PM
RETIRED
Joe Bob's Avatar
Ditto on the exhaust leak.....
2012 ML350 3.0 Turbo Diesel
Old 10-31-2008, 04:03 PM
gtc gtc is offline
abides.
gtc's Avatar
Ditto on the chip... mine would shoot flames sometimes on decel after I installed a cat bypass and open muffler. I bought a chip from Steve Wong in conjunction with an upgrade to headers, and haven't had so much as a pop since.
Graham
1984 Carrera Targa
Old 10-31-2008, 04:45 PM
It seems like I've gotten more popping with a SW chip. But only below 1500 or so RPM,
(stock exchangers -w- test pipe and Fabspeed muffler)
'84 911, some sort of red color
'05 Subaru WRX wagon
Old 11-01-2008, 04:49 AM
