Jupiter 911
Ignition wires? again
About to decide on new wires for my 1987 3.2 Targa, any ideas, oem are a little pricey! Any good alternatives? Magnacore maybe.
Lenny-1987 3.2 Targa Guards Red/SW Chip Fabspeed Exhaust/Cat bypass MSDS Inc. intake/Clewetts Euro pistons and cylinders. 2002 Boxster Artic Silver/Wifes ride. |
I put a set of Magnacores on my 88 recently and so far they have worked out nicely.
72T RS look 96 993 |
Jupiter 911
Looks like the one, so far.
I use resistor spark plugs with my Magnacores red 8.5
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Clewett makes good wires I've had them on my SC for about 2 years now no issues.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Monkey+Football
Agreed on the Clewett's, I'm running the same.
<Insert witty comment> 85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff. |
Do the Clewetts need to have the wire holders drilled out like Magnecores?
Kurt |
Monkey+Football
Not in my experience, they were plug & play.
You can get the smaller O.D. Magnacore wire sets, and you don't have to drill the holders. I still have a brand new set in the box, that I bought when they had some kind of promotion sale... too cheap to have passed on buying them. They are still resting in their "home" until I actually need them. I bought the 8.5mm reds, but from what I can tell about them, they look like some pretty decent wires. Good luck!! Tony.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
The smaller diameter Magnacores are black (I believe) but a little harder to find. I ordered the 8.5mm red ones from our host and they are working fine. The coil wire had a different plug that didn't fit so I used the old one.
I'm not into bling so I tried some black rubber dye on the wires but it didn't take. I did split the black rubber sheath around the factory setup and wrap it around the wires as they go across the fan shroud. It looks reasonable.
1988 Carrera Coupe |
