Senior Member
Shift coupler bushings
I happened to find some shift coupler bushings in my box of parts. My question, is it really that hard to change them?I see that some recommend replacing the whole shift coupler and not bothering with the task.Any input appreciated.
Old 03-20-2015, 01:55 PM
I would rather be driving
jpnovak's Avatar
Very easy to replace.
But if you have a shifter front console it will take extra time to remove it for access to the shifter.
Pelican Technical Article: Shifting Improvements - 911 (1965-86) - 930 Turbo (1975-86)
Old 03-20-2015, 01:58 PM
Senior Member
The shift coupler bushing is not under the front console it's between the seats in the back (access plate)
Old 03-20-2015, 04:24 PM
83 911 Production Cab #10
JJ 911SC's Avatar
You need a press to get the old one out and the new one in.
Of course the press will cost you more than getting this one... Shift Coupler with new bushing and cone set screw
Who Will Live... Will See
Old 03-20-2015, 05:17 PM
Brew Master
cabmandone's Avatar
It's so easy a caveman could do it.
Seriously it's really easy. If you look on youtube Ed (the coupler whisperer) has a how to video. I rebuilt two of them and kept one for a spare although I seriously doubt I'll need it for no more than my car gets driven and the fact that I used the brass bushings in the one I put in.
https://www.youtube.com/watch?v=LAD0PoC8mzo
Old 03-20-2015, 05:56 PM
wacko's Avatar
I replaced mine easily
Old 03-20-2015, 06:27 PM
If you don't have access to the equipment to replace the bushing, I would recommend replacing the whole shift coupler. I got a Wevo coupler and it was very easy to install.
1986 911 3.2 Cabriolet
"We all have a desire to create something that will show we were here. " Ferry Porsche
Old 03-20-2015, 06:35 PM
jpnovak's Avatar
Yes, most of us know that. IMO, you should replace all 4 bushings at once. 2 in the coupler, 1 on the shift rod and one on the base of this shifter rod as the ball cup.
Baseline to stock and then make changes from there. I often see the shift rod support bushing have more wear than the rear shift coupler.
Old 03-20-2015, 06:38 PM
Wew Wew is offline
SC Mutt
Wew's Avatar
I did mine and it was ok. I was not happy with the result so I went with the coupler whisperer. He makes his own. U shines and for the small price on such an important part of the driving experience I would have him do it.
My 2 cents
Old 03-20-2015, 06:41 PM
Wew Wew is offline
SC Mutt
Wew's Avatar
Spell check. Still on pain meds. "He makes his own bushings"
Old 03-20-2015, 06:42 PM
Senior Member
Thank you gentlemen
Old 03-21-2015, 09:33 AM
Low Class Yuppie
CVDH's Avatar
I was unaware that I needed a press when I did mine. I ran up the street and had a shop press the new ones in. I bought them a pizza for their trouble. Overall it was pretty easy. My old bushings were a nice oval shape!
-Cam
1984 Porsche 911 Carrera Coupe
"Porsche ownership is like AA. You can be a hedge fund manager or a stock boy at Menard's. Nobody cares. Common ground." -Bob Kontak
Old 03-21-2015, 10:05 AM
No press needed. I used a vise, a few punches, and a hammer. Coupler Removal, bushing replacement, and installation back into the car took less than 20 min. This was my first time doing it and I watched the YouTube video first.
Old 03-21-2015, 10:36 AM
Banned but not out, yet..
RSBob's Avatar
Just replaced mine with the Stromski unit sold by our host. I now get a grinding noise in first and second in the shifter. How should I adjust this?
Old 03-21-2015, 06:07 PM
TheSt|G's Avatar
There is a collar on the shift rod that can be loosened so you can slide the rod in and out of the coupler to get the ideal adjustment.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 03-22-2015, 09:28 AM
It will help to have help. Much easier with four hands.
Old 03-22-2015, 09:35 AM
OK, all work is done in such small places... how do another set of hands help?
Wayne
1980 911 SC
1960 MGA 1600
Old 03-22-2015, 10:01 AM
The other hands can move the shifter lever slightly in the direction you need to adjust, or hold shifter right where you need it when you tighten down coupler end. If you have long arms you can do it alone.
Old 03-22-2015, 12:32 PM
Originally Posted by jellonailer View Post
The other hands can move the shifter lever slightly in the direction you need to adjust, or hold shifter right where you need it when you tighten down couple end.
Yes! Correct.
Old 03-22-2015, 12:34 PM
Hello
I read the 911 bushings are oval and the 914 are round.
Does anyone have the part # for the round 914 bushing , link to it? What material is this made of?
My car is apart and now is the time to replace the original part.
Was there a write up on why the OE are oval?
BTW- I hear there are bushings made of Polygrahite and Derlin. What is the verdict from actual users?
Old 05-26-2017, 05:42 PM
