Check engine?
I think the car is pretty well sorted mechanically but I'm making a list of projects to finish over the winter. Anyone see anything obviously out of sorts with this engine aside from the sagging sound pad?
Thanks, David http://forums.pelicanparts.com/uploa...1225577054.jpg ...and the car... http://forums.pelicanparts.com/uploa...1225577605.jpg |
Impossible, for me (from the pic). Just make sure that ICV is nice and clean,..look at every single piece of rubberized hose for wear (all of 'em),...connectors removed, inspected, cleaned,......intake manifold bolts tight,......belts,..shim count correct on the belt.......
Interesting that I found my AFM cable had actually worn (scratched) the intake manifold from making vibrational contact......I repositioned her. Best, Doyle |
I need to do my sagging sound pad, what is the best way to deal with this?
After the sound pad, it appears you're down to polishing the fan & installing a cool collar.
(Ducking under desk...) |
| All times are GMT -8. The time now is 02:29 AM. |
