Czar of C.R.A.P.
dfink's Avatar
Tach black wire DME pin 31
1984 3.2 (sort of) coming out of the tach is a black wire that the service manual shows going to pin 31 of the DME. The pinouts I find for the DME don't have anything going to pin 31. I have basically stripped the car to gauges and basic lights only while installing an electromotive TEC3r. Have pretty much found everything else but the black wire.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 11-02-2008, 03:39 PM
one of gods prototypes
bell's Avatar
edit: deleted the pinout i posted as it didn't match my factory manual exactly.....
Brought to you by Carl's Jr.
Old 11-02-2008, 03:53 PM
bell's Avatar
my papers show that the tach on 84-85 3.2 dme tach output is
pin #21 black/violet and pin #11 black
Old 11-02-2008, 03:58 PM
Czar of C.R.A.P.
dfink's Avatar
Thanks; there must be a misprint in the service manual. Pin 11 to the upshift indicator would make sense. I am not sure my upshift indicator light still lights. I had the tach re-done to a sideways 8000 RPM configuration by Hollywood speedo. I was hopeing to use the upshift light for the check engine light on the electromotive unit.
66 912 Coupe
Old 11-02-2008, 04:50 PM
