Gon fix it with me hammer
svandamme's Avatar
flapperbox cables?
i recently dumped the bursch headers and went to SSI's , mfi likes it a lot...
got the flapper boxes, the heater cable , but i must missing some part as the heater cable is just that.. a cable
i seem to need a guide for the cable (1) , out of the firewall, to the flapper box, and then something at the flapper box should then keep it positioned (2)and something else to attach it to the flapperbox(3)???
90121105121 seems to be a special cable clamp? that would take care of (2) ??
anybody knows what the deal is with 1 & 3 ??
can't find those parts in PET
Stijn Vandamme
BIMDIESELBMW116D2019
Old 09-02-2006, 11:38 AM
dezzmo's Avatar
I just went through the same thing you did, I ordered a set of cables but what I really needed were the cable guides.
Try this number; 901-424-704-01 this is what I believe your looking for.
EarlyS 1017
RGruppe 663
73 911T 3.2
01 Ducati S4 Monster 00 Ducati 996
Old 09-02-2006, 02:01 PM
svandamme's Avatar
thanks DEzzmo, i was looking all over in the early section and PET, but it wasn't in there.....
also found these from the search results on that partnummer
2x
901-424-704-01-M260 18 in stock
Ships Tuesday Heater Cable Guide Tube, 911/911 Turbo (1974-86) Brand: OEM $18.25
2x Grommet for Heater Cable Guide Tube, 911/911 Turbo (1974-89) Brand: Genuine Porsche
2x
911-211-683-00-M100 11 in stock
Ships Tuesday Clamping Bolt for Heater Cable (at heater control box), 2 per car, sold per each, 911 and 911 turbo (1987-89) Brand: Genuine Porsche $12.50
not sure about this, it sounds like the thing to connect the cable to the box, but i can't visualize it from the picture..
can anyone verify my suspicing bout the hose clamp with a guide/stop built in??? is that the correct part??
Stijn Vandamme
Old 09-02-2006, 02:13 PM
304065's Avatar
Stijn, be very careful here: those were superceded many, many times so be sure they fit before you hook everything up.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 09-02-2006, 03:25 PM
svandamme's Avatar
eh John , yeah , that is indeed the problem... what do i need to operate the flapper boxes...guess i'll have to order and figure it out with trial and error, and maybe some mcgyver tactics
Stijn Vandamme
Old 09-02-2006, 03:29 PM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
I just replaced the heater boxes as well. I also found out that I need the cable guides in addition to the cables themselves. They fit into a hose clamp that attaches the duct hose to the flapper box. This clamp positions the cable/guide so that it pulls straight. Don't forget those tiny bolts with the holes in them to attach the cable. I thought I'd be able to attach them by drilling a small bolt but it didn't work. Highway robbery though--$9+ each. At least you can get the washers and nuts at a hardware store.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 09-02-2006, 03:57 PM
svandamme's Avatar
got them ordered, now it's a wait and see
need some solution, as no heat is not practical , need some heat to clear the windows in rainy weather , but fully open , it's an oven in there... whoever said 911 heat is pisspoor by design, must have had rusted out HE's or something and got high from the fumes...
Stijn Vandamme
Old 09-03-2006, 07:09 AM
Hi Stijn, maybe this picture is of use. Comes from my 1972 S
_____________________________
1972 911 2.4S Black on Black, Recaro's, SSI, MFI, dual pipe exhaust, currently running in after engine rebuild!
Old 09-03-2006, 01:33 PM
GothingNC's Avatar
Is there a bolt on the other side of the flapper box cable attachment?
Mine snapped nd the opposite side of trhe small bolt feels rounded.
Thanks !
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 12-27-2011, 03:22 AM
pete3799's Avatar
If the nut snapped off and the cable is out of it, it should push out of the flapper.
It's basically a nut and bolt (drilled to accept the cable) and some washers.
Pete
79 911SC RoW
Old 12-27-2011, 05:26 AM
GothingNC's Avatar
The nut is still attached with part of the cable.
I was wondering if there was a way to keep it from spinning or if I would be better off slicing off the nut.
Also, the heater hoses from the flapper box to the tube in the chassis are 2 1/2 diameter, correct?
The hoses installed right now turned to dust
Thank you.
John D.
2012 Golf TDI
Old 12-27-2011, 05:44 AM
