Can cracked Fuchs be repaired?
Just realized that my 8x16 Fuchs wheels have developed cracking at the hub, and run about 1-1/2" down the side of the paddles.
Question: can these be repaired? Are they unsafe for street use?
2005 Seal Gray 997 |
Banned
There might be someone closer to you but if not, call Al Reed in Anaheim.
Hang it on the wall in the garage and buy a new wheel
Hate to park $1200 of wheels on the garage wall. I did not realize that Al Reed could repair wheels in addition to re-finishing.
Think Harvey. He's the master of Porsche wheels.
Richard |
Harvey who? How do I find him?
Almost Banned Once
It might be worth taking a photo of the crack and posting it here.
All cracks can be repaired within reason but is it worth the risk in the long run? Years ago Fuchs were considered almost indestructible but now cracking is becoming more common. Anybody know what's causing this? Is it an age thing? |
I have heard that it happens to 8" wheels using spacers.
I'm sure it's a fatigue crack. 20+ years of repetative cycles add up and cause a crack that grows over time. 1.5" is a BIG crack.
Can it be welded, ground smooth, and polished? yes Will it look pretty after they fix it? yes Will it ever be as strong as the original? no Does the average wheel repair shop heat treat wheels after welding? no Will it be a risk to you, others on the road, and the shop that mounts and balances your tires? yes Is it more likely to fail again? yes Is it worth it??? not to me |
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
Artist Extraordinaire
don't know about your wheels, but there was a good punky band in the 90's called Hagfish
Terry 83 911SC / 85 Omni GLH Turbo / 91 VW GTI 16v / 18 VW Golf Sportwagen /04 Audi S4/ 16 Audi S4 |
Somewhere in the Midwest
I don't know much about this but
Lindsey builds custom Fuchs
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
You asked questions about feasibility of crack repair at 2:05 p.m. You got nearly unanimous response to either check with an expert or junk the wheels within 20 minutes. You post a for sale ad at 3:52. Without saying anything more, my feeling is you should pull your ad until you either confirm their safety or confirm they are junk.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 02-23-2009 at 06:13 PM.. |
are you sure these are real fuchs? I was under the impression that a forged wheel would bend but not crack. I would certainly not run a cracked or repaired wheel except for show purposes. I would also make sure and mark them so as not to ever mix them up!
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Real Fuchs can crack....
