(the shotguns)
berettafan's Avatar
what's the secret to drilling the holes for new '2 out' pipes for sport muffler?
How exactly do you drill the 2" holes to make a sport muffler (for the two new outlets) without some sort of fixture to keep them straight?
One thing i have learned from my limited welding experience is that the tighter the fit the less likely i am to burn holes and make a total mess.
Old 10-06-2008, 06:13 AM
use a hole saw for the size pipe you want it should be close enough to get a good weld on. Plus you can lay out the pilot holes easily.
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 10-06-2008, 06:20 AM
That's what I did for my muffler. I set the muffler on top of a couple of large jack stands so that I would be drilling straight down, it's easier to eyeball it this way. There will be a little bit of play with the hole anyway, I used a prybar in the pipe to tweak them a bit to get them straight.
Michael
Sans Porsche...for now
2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy
2010 Subaru Forester X Limited - wife's daily driver
Old 10-06-2008, 06:24 AM
(the shotguns)
berettafan's Avatar
but how did you guys keep the hole saw centered? i guess the centering bit was long enough to do its job?
Old 10-06-2008, 06:30 AM
I was doing more of a GT3-style muffler with the tips closer together but I simply used blue masking tape to map out where I wanted the holes, then marked the center, drilled a small diameter pilot hole, and then went to work with the hole saw. The pilot bit on the hole saw will keep it centered most of the way until you cut through the majority of the sheetmetal body of the muffler, then it's brute force. I had to take the grinder to mine to clean up the openings a little bit, but it worked out fine.
Michael
Old 10-06-2008, 06:33 AM
ISpeed2day's Avatar
plasma cutter.
Old 10-06-2008, 06:46 AM
Less brakes, more gas!
euro911sc's Avatar
Beaver Teeth
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 10-06-2008, 09:29 AM
AutoBahned
RWebb's Avatar
punch/drill small hole - move hole cutter or buy longer center drill for it
Old 10-06-2008, 10:33 AM
Zeke's Avatar
First, fit the pipes to the muffler. Then trace the oblong hole. Is there any other way? You can make more outlet pipes; you get one chance at the hole.
Old 10-06-2008, 12:22 PM
(the shotguns)
berettafan's Avatar
good point Milt. common sense often eludes me when working on projects like this.
perhaps i'll start w/ 2 1/4" and if the hole ends up a touch large i'll bump to 2.5".
Old 10-06-2008, 12:36 PM
sorry maybe I should have been clearer but I get to do this everyday so it is old habbit
Ben
89 944,85.5 944
914-6werkshop.com
Old 10-06-2008, 12:51 PM
"farking Porsche hero"
Rich Lambert's Avatar
Keep in mind, once you drill a hole with a hole saw, you can't use a hole saw to enlarge it because there's no where for the pilot bit to bite into.
I would think with an oblong hole a angle grinder might be your friend. As long as you don't go oversize, the hole doesn't have to be perfect.
Rich
'66 911 #303872
'07 Cayman
'17 Macan
'58 Land Rover S2 88"
Old 10-06-2008, 01:31 PM
Never mind...I just noticed you're getting advice from the muffler guy.
Rich
'66 911 #303872
'07 Cayman
'17 Macan
Old 10-06-2008, 01:32 PM
1QuickS's Avatar
Get a die grinder and sneak up to the opening you want. Trim the 2" pipe concurrently with the muffler hole and work them where they interfere. With a little back and forth fit checking you will have a pattern you can use for the second hole. You could get close by replicating the curvature of the muffler with a stiff paper model and do your initial sizing work there and then make a template without committing the muffler to your learning curve.
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 11-04-2008, 10:44 PM
Create a slightly undersize hole using traditional methods, then bend the edges of the hole outward 90 deg. with vise-grips or equivalent. This will enlarge the hole slightly as well as provide a bit of overlap onto the tailpipe. When welding, the bent edge material provides filler material for the welded joint as well as add'l support for the new tailpipe.
Sherwood
Old 11-05-2008, 12:14 AM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
My secret was to call Ben (mb911) and have him build the muffler from scratch. His welding skills are a LOT better than mine.
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 11-05-2008, 03:09 AM
(the shotguns)
berettafan's Avatar
Okay guys well i got it done and it turns out the holes were quite easy to do. And, as ben said, the hole doesn't need to be perfect to get a good weld going. nice relatively thick metal. MUCH easier than the welding i did with the pan sheet metal!
getting the pipes straight and level really wasn't that big a deal either surprisingly. for once a project went fairly well
Old 11-05-2008, 03:40 AM
This is certainly one option for a DIY project.
Sherwood
Old 11-05-2008, 06:44 AM
Designer King
Paulporsche's Avatar
Sounds like you did a great job!
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 11-05-2008, 07:32 AM
