TWJ TWJ is offline
TWJ's Avatar
Master Cylinder warning switch?
I'm looking to replace my single pole Master Cylinder Warning Switch with a correct dual pole switch. My questions is when I remove the old one will brake fluid come pouring out??? If so is there any trick to preventing this?
Thanks much.
Old 11-06-2008, 11:28 AM
emac's Avatar
TWJ
The brake fluid will NOT start pouring out. You may loose a drop or two so have the area under the MC covered. I also suggest removing the duct work before you start makes it alot easier. And whatever you do -- do not have someone push on the brake pedal this will indeed cause a mess.
Ernie 81 SC
Old 11-06-2008, 12:18 PM
TWJ TWJ is offline
TWJ's Avatar
Thanks emac! That makes the decision to do it a lot easier.
Old 11-06-2008, 12:35 PM
