Please point to the float bowl plug
Can someone upload me a pic and point to the outside float bowl plug on 71T weber carbs. Ill upload a photo if necessary
Thanks. |
Here's a good photo, but I don't have any photo editing software so I've cropped the picture to show the float bowl plug. Hope it makes sense otherwise another pelican can maybe mark up my photo. http://forums.pelicanparts.com/uploa...1225927029.jpg
http://forums.pelicanparts.com/uploa...1225927041.jpg |
What is injecting into the manifolds?
Float bowl plugs are the two 10mm hex head brass bolts. See item #64 on the attached link to an exploded drawing of the Weber. http://www.performanceoriented.com/Carb.htm
To check float levels you will need a gauge and screw it into the hole where the float bowl plug was. Mind the gas that runs out. I modified my float gauge (see picture) to collect fuel during adjustment of the float valves without continued fuel loss. Set fuel level to have the meniscus between the two upper lines, fuel height between these two lines is equal to about 0.010" change in shim thickness. Engine should be very warm before final setting and you need to take readings while the engine is running. Fuel pressure should be in the 3.5 to 4.5 psi range. New floats are a good thing to have as well. Sometimes the floats wear little divots on the lever arms on the floats themselves which may cause sticking. With a little care you can polish these divots away.http://forums.pelicanparts.com/uploa...1225929935.jpg |
Thanks, I bought a float guage from PMO and this is exactly what I needed. I will photograph the process and post if I dont catch on fire. :)
Thanks again, this place is awesome |
"I modified my float gauge (see picture) to collect fuel during adjustment of the float valves without continued fuel loss."
Interesting setup. Can you explain how you would lose fuel while the PMO gauge is attached? Do you mean if the float level is too high and overflows from the top of the gauge? Thanks, Sherwood |
If the fuel level is above the top line I unscrew the valve (brake bleed screw) and lower the fuel level so I can reset the shim stack under the float valve.
| All times are GMT -8. The time now is 04:50 PM. |
