Chain Rails
Pelican have two parts listed....one is black needs one...other is brown,.,..needs 5???
Help |
I think it is one brown and the rest black.
------------------ Robert Stoll 83 SC 83 944 |
You need 5 black and 1 brown.
Below is a diagram of how they go in. Once you have the cam covers off, you'll need to remove the engine mount yolk that bolts to the back of the engine, after placing a jack beneath the case to support the engine. You can then access the bolts that go thru the rear plate of the cam housings and remove them while holding the end of the inboard rails with needle-nose vice grips (Don't drop them!) The 2 outboard rails just pull off their small studs. [img]http://www.***************/am/assets/images/rampdiag.gif[/img] Good Luck. Nick. ------------------ _ _ __ _ _ Nick Shumaker 1982 911SC Coupe nickshu@yahoo.com PCA -- Rocky Mtn. Region |
| All times are GMT -8. The time now is 02:58 PM. |
