-   -   Spark plug wire tool (http://forums.pelicanparts.com/porsche-911-technical-forum/440102-spark-plug-wire-tool.html)
juan ruiz 11-08-2008 08:20 AM
Any ideas where can I purchase a tool to crimp this brass post connection pieces ? so far the one I found was $350.00 that is more than the entire wire set by itself. I look here first but no luck.
http://forums.pelicanparts.com/uploa...1226164823.jpg
Gunter 11-08-2008 10:36 AM
Cut the 6 new wires to the right length, then take everything to your nearest friendly Porsche or Mercedes Dealer and ask them to crimp it for you; they have the pliers.
Call first to make sure. :)
The other end is easy, it just cork-screws into the 1k OHM short connector for the cap.
Check the long Beru connectors for the right resistance: 3k OHM (They can fail)
john walker's workshop 11-08-2008 11:47 AM
wurth has/had this one. you can see the number on it. good for the star crimp. i use the belden terminal A for the crimp on the shaft. belden # 7504. best general all around crimp tool i've found.
http://forums.pelicanparts.com/uploa...1226177266.jpg
m110 11-08-2008 01:14 PM
One word....BEER
Find a big, old mercedes shop and make friends.
juan ruiz 11-08-2008 02:17 PM
thank you John, I try with coaxial wire pliers but no go, I will look into those
