Brake caliper fastener question
Hi all.
I have 4 KAMAX and 4 DERA caliper attach fasteners for my '69 911T. I believe a set of 4 came off the rear and the other set came off the front. They are nearly the same, but the KAMAX are threaded all the way to the head and the DERA have a 4 or 5 mm shoulder. I think the DERA came off the rear, but I didn't document it.
Any input?
Thanks, Bill
(I included some pic of the calipers since I spent so much time on them!)
Old 11-11-2008, 07:08 PM
68Sporto
MrJTP's Avatar
My 1968 rear calipers (S type) are laying in front of me getting new seals and my bolts are neither of the ones you show. Mine are marked GRAEK4, and possibly more important they are also marked with "10.K" which is equivalent to an SAE grade 8. However, they do not have threads on the entire length of the bolt, if that's any help.
Tony
Porsche owner since 1967
1998 Boxster
1968 911 Sportomatic project
Old 11-12-2008, 07:00 AM
djpateman's Avatar
That should not make any difference. It is just the manufacturer difference. Normally I would expect to see a higher grade though.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 11-12-2008, 07:28 AM
Thanks guys
I agree it's likely that they were interchangeable parts during the factory build. As to the bolt strength, it may be due to the fact that they are "solid rotor" brakes - not sure. I plan on putting the DERA on the back and the KAMAX on the front.
Cheers,
Bill
Old 11-12-2008, 09:46 AM
