ISpeed2day's Avatar
sounds like pebbles in muffler
My car is making terrible sounds like there are pebbles in my muffler....
Advise please...
Scared that there is motor damage...
If I turn in tight circles it stops, then when I go straight again it starts, when I turn the motor off they continue to bounce around for a few seconds then stop.
Old 11-03-2008, 10:09 AM
Detached Member
Hugh R's Avatar
Muffler or cat? If cat, the honeycomb inside may have failed. Muffler, don't know.
Hugh
Old 11-03-2008, 10:11 AM
ISpeed2day's Avatar
no cat, 1986 3.2 motronic motor, headers, sport muffler....
Old 11-03-2008, 10:18 AM
3.2 CAB's Avatar
Maybe some baffles have come loose inside the muffler??
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 11-03-2008, 10:24 AM
Maybe a bolt has sheared off?
Old 11-03-2008, 11:05 AM
T77911S's Avatar
kids putting rocks in the exhaust?
A friends kid put sand in his race car, he was filling it up like dad did.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-03-2008, 11:31 AM
Advise please...
If the motor is stopped and no exhaust is being forced through, then it may not be loose objects flying around in the exhaust stream. Possibly broken bits of baffel (or a whole baffel itself) that has dislodged and rattles through vibration and heat expansion. Turning may cause the baffel to wedge itself and stablize for a while. With the motor off, cooling of different metal pieces may cause the sound. It you're sure it's from the muffler, then motor damage risk is small--unless a blockage occurs. Best to get it looked at.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 11-03-2008, 11:58 AM
keitho64's Avatar
Check out this thread: Loud Exhaust but only when Hot after highway run – Has me Baffled
I had a similar problem but it was worse when hot. Is the sound there all the time or is it related to how hot? I have not driven mine a lot since I tightened the air injection plugs and am thinking about replacing the muffler. The other thing it to do a good visual inspection of all the pipes. Can you record the sound and attach it?
Keitho64
05 GTO
00 911 C2
64 Corvair
Chicago Burbs; the Anti-Dragon... 11 turns in 318 miles
Old 11-03-2008, 02:11 PM
N-Gruppe doesn't exist
teenerted1's Avatar
Location: *%@#ing GPS, where am I? Oh wait I see the Space Needle.
Send a message via AIM to teenerted1
you can always pull the muffler off and shake it, and if it rattles i bet the baffle is toast.
Ted
'70 911T 3.0L "SKIPPY" R-Gruppe #477
'73 914 2.0L SOLD bye bye "lil SMOKEY"
"Silence is Golden, but duct tape is SILVER.”
other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L
Old 11-03-2008, 04:10 PM
ISpeed2day's Avatar
resolved.
pulled muffler, got nuts and bolts out... darn vandals...
Old 11-03-2008, 06:54 PM
tquaglino's Avatar
Rocks in your muffler.
My 85 911 coupe had a similar sound. Though I'd describe mine as ball bearing bouncing in a coffee can.
The baffles were shot inside the muffler. I just replaced it myself. it only took 15 minutes.
Old 11-08-2008, 05:08 PM
RETIRED
Joe Bob's Avatar
Pull the muff...toss on a replacement, drive like ya stole it, have a beer, talk amonst yerselves....do it agin untill it stops.....report back.
2012 ML350 3.0 Turbo Diesel
Old 11-08-2008, 05:13 PM
