Talking Cabriolet/Convertible Body Stiffening
I am currently thinking of putting braces on my '84 cabrio so I can do a weekend track race. Any ideas on how to properly put braces on the car? I've seen cars with braces in the front but have not seen any with braces on the middle or rear part of the car. Roll bars/cages are out of the question since i also use the car on a regular basis for club meets or social functions. would appreciate any input on this.
Joseph
Old 11-14-2008, 08:09 PM
efhughes3's Avatar
Just drive it. There's not a lot you can do to effectively stiffen the car without:
a. Adding a fair amount of weight
b. Welding
You can bolt in a front strut brace which goes between the two front shocks, Do a search and you'll find all the info you need on these. These can work on cabs, coupes or Targas.
PS-What "race" is allowing you to run a car without a cage? Do you mean a DE?
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 11-14-2008, 10:18 PM
450knotOffice's Avatar
A good roll bar will stiffen up the chassis considerably and is mandatory for any event on a real race track with a cabriolet. They typically are removable, so if you don't want to see the roll bar when not tracking it, remove it.
Old 11-14-2008, 11:08 PM
RETIRED
Joe Bob's Avatar
Leave the body as is. Upgrade the suspension. T-bars, sway bars, corner balance and align it. Tires and lowering.....then flog it. Unless you are an exceptionally talented driver it will end up being above your skill level.
I know my car is.
2012 ML350 3.0 Turbo Diesel
Old 11-15-2008, 07:54 AM
Happiest when Tinkering
gsmith660's Avatar
Here is my stiffening 2 cents
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 11-15-2008, 09:25 AM
Tim
Send a message via MSN to tvanbroekhoven
Would a coupe also benefit from welding in pieces of metal as shown in the pictures ?
And isn't there a risk that the weld contains a lot of 'impurities' due to whatever is coated on the other side of the chassis (or is it 'clean' metal?)
Old 11-15-2008, 10:56 AM
gsmith660's Avatar
After I welded these pieces in I went in thru the chassis access points and sealed the scorched metal on the other side with a heavy duty anti rust I put about a pint and a half on each side and found out where all the drain points where in the rocker area and then topcoated with a good undercoat.
Old 11-15-2008, 11:16 AM
Tim
Do you notice a big difference now ?
For example, is there less flex on the body when you jack up the car?
Old 11-16-2008, 12:49 AM
3.2 CAB's Avatar
I guess that some Cabs may have more flex than others. I have seen posts by people that apparently have a "flexible flier" while others don't. I have measured the door gaps, to check if they got smaller, or wider when jacking or lifting. I have not ever found any real amount of body flex, fore and aft, or side to side. I know of some people with Cabs that have problems with opening or closing the doors when the car is in the air, so I can't see the reasons why some have flex and others don't. The Targa and the Cabs are supposed to have additional bracing, and heavier metal parts added when welding the body together at the factory. Could some of the cars that do flex, be the victim of not having the correct metal supports and have Coupe bracing? Or, could it be some just did not have all of the bracing welded in as well as others received, thus making some more flexible than others? Sort of like the old saying about never buy a car that was built on certain days of the week. I do have a front strut brace, but that is it. Just some observations. Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 11-16-2008, 09:32 AM
gsmith660's Avatar
When the car was still a targa I noticed that I could not open or shut the doors when jacked on either side, after the braces I have noticed that now I can open and close both doors when jacked. Also I installed 993 rear seats and I think that the way that triangulates it adds stiffness to the rear.
Old 11-16-2008, 05:49 PM
Yea, but Mike, you know that he can't take it to DE's without a roll bar. Auto-X's are OK without a roll bar.
I know my car is.
Old 11-16-2008, 07:22 PM
RETIRED
Joe Bob's Avatar
I never said don't put a roll bar in it.....I have one in mine.
Old 11-16-2008, 07:28 PM
