can a 69 oil filter bracket be repaired
I have two 69 oil filter to oil tank brackets that the outside edge is corroded away , can they be repaired/welded?
Thanks Lorne M.
83 SC |
Soldier of Fortune
Why not? I've seen just about everything welded here.
Do you have a pic (or sample pic) of the area in question? |
the outer edge on both can cast alum. be welded easily?
![]() ![]() thanks LM
83 SC |
Soldier of Fortune
Is that really a sealing/mating surface? If not, I think it can be built up with aluminum two-part epoxy.
Welded easily? No. But if the part is cleaned and cleaned and then baked to get the residual oil out, it can be built up with welds then machined. There must be a used one somewhere that would be less trouble and less money.
Soldier of Fortune
Here's something like I was referring to:
New, 450ºF, "Machine IT" Forms a Solid, Machinable, Metallic, Aluminum Layer. Ideal for Bonding, Repairing. Convenient pre-measured job sized kits. Just dispense, mix and apply. Machine IT HT instantly goes to work, making impossible repairs in just minutes. Easy to Use Packaged in Convenient pre-measured job sized kits. Just mix and trowel on to apply. No running, dripping or sagging. No need for molds, fixtures or clamps. Its sticky consistency will hold assemblies or parts together while curing. Excellent Adhesion without Objectionable Odors Machine- IT has excellent adhesion to smooth, rough or porous surfaces, most plastics, metals, ceramics, glass, wood, etc. Goes right to work, quickly curing at room temperature without any objectionable odors. Machinable Machine- IT cures in 2-4 hours to form a hard, durable, metallic composite that is easily machined with standard tools. Can also be tapped, drilled and threaded, etc. Applications Include High temperature repairs, rebuilding, assembling, etc. Rebuilds surfaces and even fills gaps and voids. Makes critical repairs to machinery and precision parts. It is the ideal choice for the most critical repairs. A trial kit is available for only $34.95 ea. Each kit comes complete with instructional booklet and a FREE copy of Cotronics' Latest, 2006, "High Temperature Materials Handbook. |
