I did search... Really... Partial engine drop Qs
I thought a search would pull up lots of info on this, but apparently not.
I keep hearing "partial engine drop" and it sounds sort of obvious. However, can someone more precisely define what constitutes a partial drop? I am intending to put in a new engine sound pad and a partial drop seems to be suggested for a good job. Thanks! |
AutoBahned
not fully removed
You basically disconnect fuel lines, electrical connections, shift rod coupler, etc. Then by removing the rear engine mounting bolts, and supporting the engine with a jack, the engine can be lowered (partially dropped.)
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Not worth the effort.. always easier to drop the whole engine, not a big deal .. I'm doing it again this weekend by myself
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
Don't forget to drain your oil and remove the line from the tank.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Thank you for the replies. I had been wondering if there was some "in-between" stage in which only some of the disconnections normally done for a full drop would allow the motor to come down a few inches, but it seems like you must disconnect pretty much everything you would do in a full drop anyway. Thanks for taking the time, Allan
cycling has-been
I did a partial drop to replace the cross brace that the rear mounts bolt into.
I unbolted the mount, unbolted the a/c compressor and belt for about a 4" rear drop. This gave me enough room to wriggle the cross bar out and put in the new rennspeed ss rsr bar. All the threads I saw were more involved, such as undoing the shift linkage in the back seat assess hole, but I got by without doing any of that. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Maybe I've been doing it wrong, but when I wa working on my CIS, all I did was undo the shift coupler and the two engine mount bolts. Then, I just let down my jack SLOWLY to make sure nothing got stressed. I didn't have any problems.
Alan Past: '74 914 2.0, '82 911 SC Targa, '88 911 Cabriolet, '88 911 Cabriolet again Present: '00 Boxster S "Happiness is not around the next corner......happiness IS the next corner." |
Somatic Negative Optimist
You'll need to clean the area, perhaps touch up the paint and use glue for the new pad. In other words, you'll need room to do it. If you only do a partial drop, you'll be cursing a lot and it won't turn out nice. You may want to wait with this until the engine has to come out for another reason like clutch etc.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
