Paint code decoder??
have come accross this paint code that does not copy
230-9-3 the 9 would seem to indicate that is was special order or paint to sample?? but can't find name of color. it is a light metallic green in color, any ideas pls THNX |
No, I think the 9 refers to Porsche. I'll do some digging on this for you. I'd like to know the VIN for my records however.
it is a 1973 911T
will be glad to PM you the vin |
Great, that helps my research a lot. Have you got the COA? That should provide the correct color name. I suspect it is a "custom" color, so that makes the car a little more unusual.
http://www.356-911.com/modelinfo/911colours/911colours7173.htm
you might add a color and a picture to this site. |
German, but try this. Click on the basic color for other options.
http://www.911c1.de/porsche/Technik/farben/farbcode_weiss.htm |
Thanks guys,
231 sambesi-grün 1972-1973 is the closest in number code, this being 230- here is a link to the actual color on the car http://www.fototime.com/24E2230A38ABDFB/medium.jpg |
That code is not listed on my favorite color site: http://www.elferhelfer.com/farben.htm but it is on this page: http://members.rennlist.com/tweedt/glasurit.htm as dunkelgrun metallic.
230 dunkelgrun metallic it is then, although it is listed as a 1972 color,
thanks guys much appreciated Quote:
That is a definitive source. Translates to Dark Green metallic. It must have superseded 221 in 1972. As much as I use http://www.elferhelfer.com/farben.htm as a source, I find they have a lot of errors and omissions. There are certainly a lot of codes used in a year that are not listed in the usual sources. Thus what I am trying to do is to collect actual badge paint codes that are matched to a VIN to produce a comprehensive list of paint codes used each year.
I really would like to have access to a correct and complete list of paint colours with year and photos. Neither elferhelfer nor 356-911 have been updated for the last years as far as I can see. Regards, Einar Irgens |
Perhaps Pelican will be willing to put the paint codes in their new technical pages.
I collect codes by searching through threads here and elsewhere. I'm particularly interested in codes that are not found in the usual sources. Perhaps I should start my own thread, asking for more information. |
| All times are GMT -8. The time now is 07:04 PM. |
